16 Pages «<34567>»
Jonny's Sovereign Options
#81 Posted : 16 April 2014 17:55:14
BigGrin Well done Jonny nice to see you back on the old girlCool
#82 Posted : 18 April 2014 18:08:17
Hello there shipmates...I promised another update on my progress so here it is. Continuing with where I left off, I added a few more layers of planking...I found many planks of varying widths and thicknesses and colour, but picking the best, I plodded on. So here are some more pictures..
Blink
jonny7england attached the following image(s):
#83 Posted : 18 April 2014 21:25:43
Jonny
Really pleased to see your back Into your stride and pressing on with your build.
You have pulled a potential show stopper with that frame back on track brilliantly.
Looking forward to seeing more of your build over the coming weeks.
Tony
KobusBeukes
#84 Posted : 18 April 2014 21:48:20
Hi Jonny
Good to see you back! Laugh
Like Alan has said before, this is not a race, take your time and complete your build. I'm about 12 weeks behind because I deviated from the second planking and are cutting my own planks.
Enjoy the build!Drool
Kobus
Current Build
#85 Posted : 19 April 2014 15:48:51
Back again shipmates with yet another posting of my build diary fetching it up to date (well, as near as damn it???)and then I can continue with a regular posting from here on in...
BigGrin
At this point, I must explain my position...I have very limited mobility and work from my wheelchair..in this position I am able to lay the build upon my lap and work from there. As I was in the process of completing all of the planking below the lower gun deck, I must have applied too much downward pressure while working and accidentally snapped a good 10mm or so from the tops of rib 15..Yes..another setback struck again!!!!
OhMyGod Cursing Crying Crying
To remedy this, I cut a 12mm strip of scrap wood off of the fret that rib 15 first came from tidied the top of the broken rib 15 and glued the scrap 12mm part onto rib 15.
#86 Posted : 19 April 2014 16:06:48
Looking good Jonny - does three weetabix have the same effect as three shredded wheatConfused
strip sorter is a great ideaCool
GluedFingers
#87 Posted : 19 April 2014 16:13:57
A GREAT idea with your toiletroll-holders, John! ThumpUpThumpUpThumpUp
Unfortunately we don't do weetabix here at home. But I'm pretty sure I can find a replacement. BigGrin
Smile
Thanks again,
Adrie.
#88 Posted : 19 April 2014 17:28:20
Thank you my friends...Surprising what you can do with ordiary household rubbish...
Blink Blink
Now here are some pictures of my build to date..All I have to do is the sanding of the hull to prepare it for the next stage...
#89 Posted : 19 April 2014 17:52:05
#90 Posted : 19 April 2014 22:27:46
Hi Jonny, some really nice work there, the planking is looking spot on....Cool Cool .. Love your idea for strip holders, I use empty pringle tubes taped together, same idea and very effective for storing strips... Cool Cool .. I also have to tip my hat to you mate..... how you can work from a wheelchair with this beast sitting on your lap and produce the results you do is simply mind boggling.... especially when later in the build you start adding all the fiddly intricate pieces....Cool Cool .. credit to you, keep up the great work.....Cool Cool
George1
#91 Posted : 30 April 2014 10:02:24
Hi Jonny
Your build looking really great. Cool Cool
I hope I'm as successful regarding your planking.BigGrin
Getting closer to the day when an issue has planking within.BigGrin
George1
Building HMS SOTS
George1
#92 Posted : 06 July 2014 03:01:21
Hi Jonny. BigGrin
Came in to check out "bull clips" as per your reply my thread. Cool Cool
Now I know what they are and description. Thanks mate. Cool Cool
Just a further query; Re the stern fill-in; The top plank bow to stern to be level with the top plank of stern fill-in. Now I noticed that you have shaped this plank with the others to shape of stern fill-in yet official build shows leaving at least 10 mm plus overhang first plank to stern end. Rest below can be shaped. Is there an insert that fits between the two overhangs.ConfusedWhy does this overhang need to be there? It is rather confusing. Confused
Hope you can clarify for me. BigGrin
George
Building HMS SOTS
#93 Posted : 06 July 2014 19:05:52
George1 wrote:
Hi Jonny. BigGrin
George
Hi there George...Glad that you saw the bull clips that I mentioned. You may have to cannibalize a few clips to get the end result..i.e, the part that slips over the plank that you are working on? As for your further query, I don't quite understand what you are trying to point out? If there are any pictures to refer to regarding your query, I would be only too glad to answer your question...
Wink
#94 Posted : 06 July 2014 19:50:10
BigGrin A lovely bit of planking m8 keep the pics coming ThumpUp Rgd Martyn
George1
#95 Posted : 07 July 2014 02:41:09
jonny7england wrote:
George1 wrote:
Hi Jonny. BigGrin
George
Wink
Hi Jonny. BigGrin
Re the plank overhang first plank from bow to stern to top plank stern infill.
See Tomick's Official Build Diary SOTS issues 21-25 post 4 pic three down. Confused
You will see all planks shaped to stern planking except for that first plank which is left as overhang. I thought it must be for some insert to go between otherwise why leave it overhang. Confused
Hope you can clarify for me.BigGrin
George
Building HMS SOTS
#96 Posted : 07 July 2014 08:20:41
George1 wrote:
Hi Jonny. BigGrin
George
Wink
Hi Jonny. BigGrin
George
Hi George...Thanks for the extra info mate and as for the overhang?...there is the addition of two gallery side panels and rear panel...Issue 30 and after fitting these panels the planking seems to have been cut back, though there is no written evidence stating to cut it back? See Mr T's posting...Issue 30, pictures 2-3 and 4, the overhang is missing! Sorry for the delay in answering George, I hope that it helps mate...Take care now.
Wink
#97 Posted : 07 July 2014 13:12:37
Looks really good, enjoying your build Cool
#98 Posted : 07 July 2014 14:48:50
Thank you for your very welcome comments my friends..It is well appreciated...Smile
#99 Posted : 07 July 2014 16:13:43
Hi Jonny
Your hull planking looks real good.
I always see this as the biggest hurdle to get right in any build and getting this right takes some real skills and patience.
Your doing well.
Kind regards
Tony
#100 Posted : 07 July 2014 16:23:11
Thanks Tony...Your nice comment really appreciated mate...Wink
16 Pages «<34567>»
This page was generated in 0.853 seconds.
