9 Pages <1234>»
SOS Options
George1
#21 Posted : 17 April 2014 07:38:09
Hi bb1949
The builds look great. Cool
At least you have some experiences re rigging etc that should come in handy re SOTS.BigGrin
I'll be following you closely at those stages.BigGrin
George1
Building HMS SOTS
bb1949
#22 Posted : 18 April 2014 14:45:03
I found my biggest challenge was the rope leaders. I had tried a lot of methods from various sources and then settled on building the ladders in situ. Every horizontal rung connecting to the vertical line is a clove hitch. I choose the clove hitch because it compresses well and is easy to do with a needle. The problem with this method is to get the line even and the tension right. It took some practice but after a while I could do it very quickly. I also had to set up both sides of the mast to ensure everything was in line but it worked and I was happy with the result.
George1
#23 Posted : 22 April 2014 07:30:23
Hi bb1949
You OK? Haven't seen you on since 18th. You were going to post either the 18th-19th re your manufacture of ship supports.Confused
Hope all OK. Mellow
Perhaps you were away for Easter?
George1
Building HMS SOTS
bb1949
#24 Posted : 22 April 2014 15:53:26
Hi George and thank you for your concern. All is good. Easter was full on but Michael (our shop fitter son) had too much work having recently relocated the workshop to a 3000 m sq premise. This means I did n't get to exchange ideas on the fittings so I used a cruder approach. It looks untidy but works. I will show pics tomorrow. Also the family found 720 Easter eggs in the back yard. Some bunny put them there, but hey the mob had fun. And all were over 30.
I have started with balsa infill for the other boat project, which is progressing slowly due to my work commitments and I only have about an hours window to make noise ie using sanders etc. Part of our overall plan is to build a studio which is scheduled for july so I can make noise for a little bit longer in the evenings.
BBBigGrin
#25 Posted : 22 April 2014 16:18:55
Great start on the build and congrat's on your first medal Cool
George1
#26 Posted : 23 April 2014 06:32:06
BBBigGrin
Hi bb1949
Glad to hear all Ok BigGrin
I've managed to get my better half to remove all her stuff covering one of my work tables in the garage so now I have some space to work better. You'll see in next pics. The threat of sanding within the house otherwise did the trick. Laugh
I have nothing to post in build diary till we get number 7 Thursday.BigGrin
George1
Building HMS SOTS
bb1949
#27 Posted : 23 April 2014 14:01:49
Hi George, yes I saw the pics and very impressed all round. I have been trying to occupy myself with other builds at the moment and making slow but measurable progress. I thought I should add some other pics of a current build which is a cross section of HMS Endeavour which I have thoroughly enjoyed doing so far. As you can see I still have bits to go but I am patient.
bb1949 attached the following image(s):
bb1949
#28 Posted : 23 April 2014 14:08:45
Also have added some pics to show how I added the fasteners to the false keel. Included is a pic of the two types of bolts I thought of using, electing for the four point pin as this provided better security. What you don't see is the pieces fitting over the closure have been rounded out to fit around the circular centre of the securing nut which provided better security when fitting to the false keel. I didn't worry to much about being pretty with the finish but made sure there was plenty of clearance for the planking yet to come.
bb1949
#29 Posted : 23 April 2014 14:11:16
The securing device is on the right. The centre and left is the other option.
George1
#30 Posted : 23 April 2014 17:56:55
Hi bb1949
Looks like you've got it in hand. Cool
Regarding doing this re threaded bolts etc.,for a stand I'm not sure at the moment if I'm going this way eventually. Certainly I'm going to need supports once planking complete on hull so will maybe make temporary wooden support but my vision which may only stay a vision BigGrin is to eventually make a base board with 4 inch side strips and use plaster of paris to sink hull into then carve or make bow waves and eddies etc., then paint like the ocean for the final display. As an artist I have done this before with oil paintings where trunks of trees and branches are raised along with rocks etc. It's just another method in art. Anyway I'm not 100 percent sure yet. BigGrin
Love your other models Cool
Perhaps I should have started on those first before SOTS to gain exerience but too late now BigGrin
George1
Building HMS SOTS
bb1949
#31 Posted : 24 April 2014 11:36:58
Wow! That is something I am not game enough to try without a lot of practice. Fortunately you have the artistic talent (which escaped me at birth)and what you have outlined sounds terrific. I can actually hear it! (Well I am recalling my sailing days as a youngster). Any way here is today's results at the end of the long awaited issue 7. (It's going to be a big one).
George1
#32 Posted : 24 April 2014 11:37:30
Hi bb1949
Thought I'd just give you my latest find.BigGrin
Regarding the brace cover join position in issue 7.
While as you know re my thread I put it higher so wouldn't effect the curvature of the rib frame, well it appears it's not going to help much when the next two rib frames come in future issues, as the bottom of next rib frame is at least 1 plus inches up from bottom of keel so still leaves a lot of the braces jutting out past the curvature. Laugh
Actually the stern is rather confusing at that point so will have to rely on instructions and other builds regarding same. BigGrin
George1
Building HMS SOTS
bb1949
#33 Posted : 24 April 2014 11:38:02
Blushing opps the pics
bb1949
#34 Posted : 24 April 2014 11:41:07
Wow! ok just read your note I can still take the braceing off ( I hope) back soon!
bb1949
#35 Posted : 24 April 2014 11:45:18
Hmmm a bit of effort but I have got them off safely and no damage! BigGrin I will go and have look at the builds for some others and see what they have done. Thanks for the heads up.
#36 Posted : 24 April 2014 11:45:41
looking sweet bb. well done.Cool
George1
#37 Posted : 24 April 2014 11:46:22
Hi bb1949
Looking very good. Cool
I take it re bow left side that the edge bow piece is only photographic distortion.?
I see where you lifted number 7 braces regards curvature rib frame. BigGrin
Our problem now is the next couple of issues are the row boat and other items till we get those other rib frames. BigGrin
George1
Building HMS SOTS
George1
#38 Posted : 24 April 2014 11:53:15
Hi bb1949
Well Tommicks build shows level with bottom of false keel regarding issue 7 join so maybe later when planking starts there may be sanding instruction. Confused
Whatever we'll get past it. BigGrin
I've already stuck mine as you see in pics so too late now to reposition.Laugh
George1
Building HMS SOTS
bb1949
#39 Posted : 24 April 2014 12:17:52
Yes I was able to find the revision later in the formal build diary and added pics to your post fro reference. I have made the corrections and everything is in line and square so still on track.
bb1949
#40 Posted : 24 April 2014 12:19:12
I have to remember not to go back before posting pics. javascript:insertsmiley('Blushing ','/images/emoticons/msp_blushing.gif')
9 Pages <1234>»
This page was generated in 2.399 seconds.
