jock Options
jock
#1 Posted : 17 April 2014 11:09:35
I read in one of the forums which I can,t find, that they added weights to the hull to stabilize it and not be top heavy. Any thoughts?
Previous builds
Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour
http://jockspage.webs.com/
#2 Posted : 17 April 2014 11:36:37
jethro
#3 Posted : 10 June 2014 08:07:09
hello Jock
check out the build discussion page 8 theres a thread there titaled ballasting ideas from captain david dated 7/3/2013
jethro
jock
#4 Posted : 10 June 2014 13:05:39
Thanks for the link. I'm adding some red gum pieces between some of the frames, this should add some stability when rigging is completed, don't forget these ships carried ballast not only to keep the vessel upright in the wind but also to counter balance the rigging.
Previous builds
riff-raff
#5 Posted : 21 July 2014 17:47:42
Considering the weight of the hull (Frames, decks, cannons, and other parts) compared to the weight of the rigging (a few dowels and blocks) I don't think the need for ballast is something that I would consider.
All 6 of the tall ships I have built stand perfectly stable.
Built:
riff-raff
#6 Posted : 21 July 2014 17:48:44
Just to add.... The weight of these ships when just moving them about for dusting etc can be quite considerable in them selves.
Built:
#7 Posted : 21 July 2014 22:55:01
Hi Jock, I'm well into this build and have got to issue 99... Have to say, apart from the balsa infills I did I have applied any other ballast... so far she is stable in her cradle and quite weighty.... Don't see any need to weigh her down further....
This page was generated in 0.674 seconds.
