More issues with the formast plans Options
#1 Posted : 19 April 2014 15:52:08
Just a warning that there is a 6.5mm error on the lower forms plan. he build plan for the lower for mast shows the rubbing paunch at 168mm but on the plan showing the bindings added the paunch is 6.5mm shorter.
I would recommend using the construction plan and ignoring the competed plan. his is important as the measurements given for the lower block and tackle will be wrong and if you are adding etch boarding pikes these could foul the bindings. Even more importantly you can not place the bindings as shown as the third binding up will snag on the bottom of the paunch.
This page was generated in 0.024 seconds.
