jock Options
jock
#1 Posted : 21 April 2014 09:04:42
Just a small question, how long is the bowsprit from the stem. I'm building a protective box (cat proof)
Previous builds
Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour
http://jockspage.webs.com/
#2 Posted : 21 April 2014 09:14:13
Hi Jock, according to instructions Length: 1100mm, Height: 900mm, Beam: 400mm
jock
#3 Posted : 21 April 2014 10:18:54
What I'm after is the distance from the stem to the tip of the bowsprit
Previous builds
#4 Posted : 21 April 2014 10:28:14
Hi Jock, its 1100mm from stern to bowsprit tip.... This may help... http://forum.model-space...aspx?g=posts&t=4725
jock
#5 Posted : 21 April 2014 10:35:17
Sorry Guys it's the distance from the STEM not the stern,senior momentBlushing
Previous builds
#6 Posted : 21 April 2014 12:27:05
Hi Jock, that dimension is probably an unknown as I don't think anyone has recieved the bowsprit plans as yet - you could "guestimate" by subtracting the hull length from the total length? Surely though if you are wanting the info to build a box for display then the total length should be what you need?Confused (unless I'm missing something)...
#7 Posted : 21 April 2014 12:35:27
Hi Jock, the bowsprit is 325mm long and you will have to add some extra for the overhang of the fighting top.... Cool Cool ..
Hope this helps...
