162 Pages «<122123124125126>»
#2461 Posted : 20 April 2014 17:42:45
BigGrin Absolutely lovely Alan can't wait for my next issues BigGrin bril job BigGrin Rgd Martyn
#2462 Posted : 20 April 2014 23:27:01
Thanks Martyn, appreciate your very kind comments... Cool Cool Great to see you are keeping up with the issues too and I think from here on most of the work will be in painting and adding all the bling with a little bit of building thrown in.....Cool Cool .. Thanks again....
#2463 Posted : 21 April 2014 22:35:48
Hi everyone, today managed to get quite a bit done on the old girl.... Continued with issue 84 by fitting all the vertical cornice's on the port side, then moved onto fitting 6 cleats onto the upper quarterdeck followed by a further 10 to the quarterdeck... Cleats were first given a coat of primer followed by 2 coats of acrylic metallic bronze. Finished off issue 84 with the priming and painting of the stern statuettes.... Cool Cool
Moved onto issue 85, first attaching the stern statuettes but I have left the final one off until I receive the wreath thingamabob the statuette sits on in issue 86, want to ensure I get it positioned just right.... Cool Cool .. Next task was to construct the framing that sits on the bulkhead of the upper quarterdeck, this proved to be little fiddly but got there in the end..... Stained the framing with two coats of medium oak before finally fitting the brass mesh to the back.... Swapped over the mesh with 1mm diamond mesh and when dry fitted in place....Cool Cool .. Next task is to construct the railings for the front of the upper quarterdeck...... Cool Cool .. Am very happy with how everything is coming together..... Happy building all...
#2464 Posted : 21 April 2014 23:17:38
BigGrin Hi Alan
The gold fittings certainly set her off
#2465 Posted : 21 April 2014 23:29:27
BigGrin Hi Alan
Thanks Andy, lots more gold fittings to be added yet.... Cool Cool
#2466 Posted : 22 April 2014 01:48:00
KobusBeukes
#2467 Posted : 22 April 2014 07:03:08
Hi Alan
Begining to wonder why she was called the Sovereign of the Seas, due to her fire power or to all the bling on board?
She is looking stunning now! Drool
Kobus
Current Build
#2468 Posted : 22 April 2014 09:03:53
stevie_o wrote:
Lovely work Alan, just when I think the hull decoration is over there is yet more to add, it never endsBigGrin
Thanks again for you kind comments Stevie..appreciated... Cool Cool .. I think for the next few weeks anyway ornamentation will be continually added, lot more to go yet....Cool Cool
#2469 Posted : 22 April 2014 09:05:41
KobusBeukes wrote:
Hi Alan
Good question Kobus and I have no idea why she was named SOTS but she certainly looks the part.... BigGrin BigGrin .. Thanks again for the very kind comments.... Cool Cool
#2470 Posted : 22 April 2014 17:14:27
Issue 85 now complete with the making up of the upper quarterdeck railings..... Straight forward construction process but for those following, be extremely careful with the framing it is extremely delicate to say the least, probably the most delicate piece of the build to date...... Blink Blink .. Railings have been given 2 coats of medium oak stain.... That's it until the release of the next issue but at least I can have a few hours working on the Titanic..... Cool Cool .. Happy building all....
#2471 Posted : 24 April 2014 21:14:36
Issue 86 now complete, not much to do in this one except painting and adding more bling to the lower stern.. some intricate painting and am happy to say I have joined the penny club.....BigGrin BigGrin .. This means I have almost a week on working on the Titanic so should be able to move that one forward.... Cool Cool
#2472 Posted : 24 April 2014 21:19:44
Brill stuff Alan, I bet before starting this (your 1st ship) you never imagined it would look this good.
This is the only diary on here where I don't mind you saying you are going to put this down for a week, because then we get to see the Titanic move forwardLaugh
#2473 Posted : 24 April 2014 21:44:21
Thanks for the kind comments Stevie... when I first started this I had absolutely no idea what I was letting myself in for, 18 month in and I still have masses to learn.... I am very pleased with how she is progressing but I would still like to see my first build complete.... long ways to go yet.....Cool Cool
#2474 Posted : 28 April 2014 20:16:12
Hi Alan, Drool Drool
Great work, this is turning into a masterpiece.
Cool Cool Cool Cool Cool Cool Cool Cool
Looking in as often as possible and it`s an experience every time.
WTG
#2475 Posted : 28 April 2014 23:39:00
WTG
Thanks Derek, always appreciate you taking the time to look in..... appreciate the very positive comments from you..... Cool Cool .. Thanks again....
John Passmore
#2476 Posted : 29 April 2014 07:29:42
Publisher Medal: Featured Build of the MonthOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Hi Alan
Just been looking at your build and must say it looks absolutely terrific.
I just hope mine will reach just half this super standard. I'm only up to issue 7 so far and as I said to my newsagent supplier recently I hope to live long enough to complete it! (I'm 72)
Just one little query - how are the cannons installed? will they fit through the ports? Are they glued into place?
JohnP
#2477 Posted : 29 April 2014 09:16:01
John Passmore wrote:
Hi Alan
JohnP
Hi John and thanks for your very kind comments... I like you started this as a first timer to this hobby so am sure your's will be just as good. Follow the instructions, read the diaries available for tips and techniques especially Mr T's official build diary....Cool Cool .. As for the cannons, the cannons on the top decks are full cannons, ie they are complete with carriages and rigging. Cannons on the lower decks are barrels only where a hole is drilled into the dummy gun supports inside the gun port and the barrel is inserted into the hole. When you get to the stage of fitting the dummy gun supports then make sure they are securely fitted to take the riggors of drilling into at a later stage.... Cool Cool Hope this helps and thanks for looking in...
#2478 Posted : 29 April 2014 11:18:32
Brilliant job there Alan, she is looking real grand.
#2479 Posted : 29 April 2014 22:57:57
Thanks Hans, always appreciate you looking in and commenting.... Cool Cool
John Passmore
#2480 Posted : 30 April 2014 03:13:41
Hi Alan
Re your post 2536 - cannon installation on the lower decks. Many thanks for the info.
JohnP
Guest (16)
This page was generated in 1.964 seconds.
