2 Pages 12>
SandyM Options
SandyM
#1 Posted : 22 April 2014 13:37:16
Hi All,
I have unfortunately had little time to work on S.O.T.S but here is an up date of my build,
SandyM attached the following image(s):
Various balsa aircraft both rubber powered and RC
Billing Jyland
Billing Wasa
Billing Dutch Royal Barge (gold medal winner Germany 1975)
Scratch built HMS Victory using HMSO plans hull size 26"
Scratch built Yamato Hull size 8'8"
De Pardo HMS Bounty
Current build Sovereign of the Seas
#2 Posted : 22 April 2014 20:10:20
BigGrin Looking very good Sandy a credit to youCool
SandyM
#3 Posted : 22 April 2014 20:31:29
Thanks a lot for your nice remarks Arpurchase, everything is noticeable with the camera, I had not released there was so much dust on the build bench so I have been busy with the hover and will have to keep her covered from now on.
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
#4 Posted : 22 April 2014 20:46:59
#5 Posted : 22 April 2014 22:27:17
Looking great Sandy, some lovely work..... Cool Cool
SandyM
#6 Posted : 23 April 2014 09:40:54
Thanks very much Steve and Alan. Work is progressing all be it slowly. I am concentrating on fitting out the lower gun deck now in an effort to get it closed up in order to reduce the dust surfaces.
All the best guys,
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
SandyM
#7 Posted : 08 August 2014 22:07:08
Got back to building again, lots to do.
First 10 canon fitted to Lower Gun Deck only 18 to go then the lights.
Anchor trundlehead and messenger cable for raising the anchor.
I also secured the bowsprit to a stump of the foremast and deck plate. There are plenty decks above to secure the rest of the foremast.
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
#8 Posted : 08 August 2014 22:28:09
Sandy
Just saw this and could not believe it's SOS. It looks absolutely brilliant.
Time is always a show stopper to most peoples hobbies but keep at this one because you have something very special coming together here.
Happy modelling
Tony
#9 Posted : 08 August 2014 23:18:24
Beautiful work Sandy and it's great to see your progress.... going to be a stunner when complete.....Cool Cool
SandyM
#10 Posted : 09 August 2014 08:15:02
Thanks very much Alan and Tony for for kind remarks. By the time she is finished this site will problely working on the relaunch of the mag.
I am looking forward to see if the lighting works out.
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
#11 Posted : 09 August 2014 10:06:34
Hi Sandy,
That's one awesome build Sandy thank you for posting.
Trev.
SandyM
#12 Posted : 09 August 2014 16:00:50
Thanks Trev
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
SandyM
#13 Posted : 27 August 2014 09:10:52
Stern Chasers,
I have found that with a bit of cut and paste I can make the larger Stern Chasers using the half canons supplied.
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
#14 Posted : 27 August 2014 10:27:17
Sandy
What a brilliant model you have taking shape here.
Very clever idea with the stern chaser guns and very well executed.
Happy modelling
Tony
#15 Posted : 27 August 2014 10:31:37
Nice added detail Sandy Cool
SandyM
#16 Posted : 27 August 2014 11:39:39
Thank you very much Tony and Mr T
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
#17 Posted : 27 August 2014 21:13:09
Hi Sandy, great idea with the stern chasers.. gives me food for thought as I have spare cannons and half cannons already in stash..... Thanks for sharing and look forward to your next post.....
SandyM
#18 Posted : 28 August 2014 08:53:26
Thanks Alan,
I needed canons to be the right scale length for stern counter on the middle gun deck and had made some but the quality of the castings just was not there. These ones are about 1.5mm to long but I can live with that. After I chopped of the end of the barrel I drilled a hole in the stump matching that of the half canons and mounted barrel end as per the mag.
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
#19 Posted : 28 August 2014 11:39:07
Now that's good thinking, well done Sandy.
SandyM
#20 Posted : 28 August 2014 12:43:13
Thanks very much Hans
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
2 Pages 12>
This page was generated in 0.891 seconds.
