Height of car Options
greveleer
#1 Posted : 22 April 2014 13:55:53
Rank: Beginner Level 1
Hi all,
I am building my F1 car and after finishing the rear suspension I noticed that I have a height difference between front and back.
I didnt measure it but i believe the difference is around 10mm.
How do I solve this? Can someone measure the heightdifference on his car?
Thx
#2 Posted : 22 April 2014 14:18:55
The pack 14 download contains information about how to adjust the ground height of the model.
greveleer
#3 Posted : 22 April 2014 16:24:40
Hello Tomick, thanks for the quick response.
I checked stage 53 document. It only mentioned the Left rear wheel. No information about height setting.
In stage 54 its the setup of the rear suspensio, but nothing about height setup.
I measured the difference in height FR:5mm from ground, RR: 20mm from ground
thx
#4 Posted : 22 April 2014 16:50:37
You need to look at pages 229 - 223 of the pack 14 download, which is titled "Adjusting ground clearance"
greveleer
#5 Posted : 22 April 2014 16:52:17
I have no idea how to find this downoad, can you post a link?
thx
#6 Posted : 22 April 2014 17:19:36
If you obtain your RB7 via Germany, then it is likley the information is provided at the same point as the Australian build, which is within issue 37, pages 7-10 titled "Adjusting ground clearance".
The UK download has the same information for UK customers but at a much later point.
Bdizzle84
#7 Posted : 25 April 2014 11:05:04
Tomick,
I read up (in issue 37) about adjusting the front ride height of the car. It says about adding spacers. Will these be provided at some stage or is a trip to the RC shop required? As far as I can tell the front end is way to low to be usable at the moment.
Building: RB7 Nitro / Senna MP4/4 Finished: McLaren MP4/23
Brad.
#8 Posted : 25 April 2014 12:01:07
I've not yet seen any shock spacers provided as yet, but they can be purchased via eBay or a good R/C car store and generally sold in sets of varing widths.
greveleer
#9 Posted : 26 April 2014 15:12:51
i was able to move up the front end for a few mm.
Will need to buy some shock spacers. Didnt you have this issue Tomick?
#10 Posted : 26 April 2014 16:22:16
We only have one rear wheel delivered which has yet to be fitted. I would not make any adjustemnt until the content has been delivered.
Nightrider
#11 Posted : 27 April 2014 04:25:55
I don think the Germans had any problems likes this..
Well no one mentioned any issues with the ride height on the forums .
This page was generated in 0.405 seconds.
