rocker boxes Options
monoi
#1 Posted : 22 April 2014 15:08:01
Is it me, as I find that the 19mm rods for the rocker boxes to be slightly too short, and those rockers do not easily align with the ring?
Has anyone else experienced some issues there?
#2 Posted : 22 April 2014 20:36:54
BigGrin Hi Monoi
What I did here was to cut all at 20mm and individually fit each one, drilling the holes out slightly bigger also helps and gives scope for movement /placement
monoi
#3 Posted : 23 April 2014 20:45:04
Hi Andy,
Good to know I'm not the only one.
I have run out of wire though now!
Pascal
#4 Posted : 24 April 2014 20:37:45
BigGrin I have quite a bit spare but I tend to use up all the old bits up before cutting into new stock
This page was generated in 0.152 seconds.
