21 Pages 123>»
John Passmore Options
John Passmore
#1 Posted : 26 April 2014 01:05:51
Publisher Medal: Featured Build of the MonthOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Hi everyone
This (SotS) is my first build ever and I'm up to issue 7 without any problems so far. I get all my tools and things from a very good modelling shop in Perth 1-1/2 hrs drive away.
I have been reading Tomics' excellent build diary and have an initial question; There is a Stand advertised for GBP 19.95. Will this be available in Australia at some stage? There is no indication this early so I have inserted 2 captive nuts in the false keel as described in issue 6, but will need to decide on the stand when the time comes for planking (in order to provide bolt access holes - or not).
#2 Posted : 26 April 2014 09:11:34
Hi John,
Welcome to ModelsSpace Cool
Yes, the stand will also be offered in Australia at some point.
#3 Posted : 26 April 2014 09:24:10
BigGrin Hi John
Welcome to the Forum
AdamHall
#4 Posted : 26 April 2014 10:09:32
G'day John.
Welcome to the forum. I noticed that you are from Mandurah. I'm just up the road in Safety Bay.
I'm also undecided about the final mounting arrangement. Still tossing up between a cradle or threaded rod. I understand that the ship will be about 5kg in weight when completed. Thus, I am not sure whether the threaded rod will have enough strength whenever it has to be moved. Also don't want the ship rolling over in the cradle.
Maybe a combination of the two types will be the way to go?
Enjoy, hope to see some pics of your progress.
Adam.
#5 Posted : 26 April 2014 11:58:49
welcome a board, and hope to see some pics of your build,good sailing m8.Cool
George1
#6 Posted : 27 April 2014 03:34:09
Hi John
Welcome to the forum.BigGrin
I did welcome you on Build Discussions re a post, but better here on Australian Forum. BigGrin
Look forward to your build. Cool
George1
Building HMS SOTS
John Passmore
#7 Posted : 27 April 2014 05:30:44
G'day all
Tks for the welcome - what a nice friendly site this is!
I have a couple of pics of my build to date and will include in Build Discussion when I can figure out how to attach in this Forum.
JohnP BigGrin
John Passmore
#8 Posted : 28 April 2014 06:33:46
AdamHall wrote:
G'day John.
Adam.
Hi Neighbour
I've decided to allow for both options. I'll leave holes for the threaded rods, but if I decide on the the cradle option I can always plug 'em up. I'm thinking solid brass, flared fittings would look good.
I've got pics of my build to date but I'm still grappling with how to attach in this forum.
John Passmore attached the following image(s):
John Passmore
#9 Posted : 28 April 2014 07:29:45
G'day fellow shipbuilders,
I finally have success in attaching some pics of my (SotS)build to date.
I have inserted captive nuts in the false keel which will be a mounting option.
I only had one minor problem thus far, the brace plates between rib frames 7 and 13 were oversize and encroached the mounting slots. Carefully filed back, so rib frames are nice and square.
All rib frames except 20, 21 and 22 are glued in as it seems that adjustments are needed to brace plates at the stern joint. These braces have been glued.
Now I'm aware of this forum, I will post progress from time to time.
Thanks for your welcoming messages.
George1
#10 Posted : 28 April 2014 10:09:30
Hi John
Your build looking very good. Cool
Pleased to see you now have pic problems overcome.BigGrin
George1
Building HMS SOTS
#11 Posted : 28 April 2014 10:19:57
very nice start john,keep up the good work.Cool
AdamHall
#12 Posted : 28 April 2014 16:46:07
Good work so far John.
Glad to see that you have managed to get the posting of pictures sorted.
Adam
#13 Posted : 29 April 2014 09:20:12
Hi John, looks as if you are off to a great start there, the jig or dry dock looks spot on and will certainly help to ensure everything is lined up correctly..... Cool Cool . Will be following you build with a great deal of interest.....
bb1949
#14 Posted : 29 April 2014 13:15:45
Hi John. Yes this is looking very good and will watch your progress with keen interest.
#15 Posted : 29 April 2014 13:48:50
Marcel
#16 Posted : 29 April 2014 14:18:19
It looks beautiful and neat. I suggest you go for the Balsa in fills at the bow to support the tapers of the strakes.
Sovereign of the Seas
John Passmore
#17 Posted : 30 April 2014 01:18:44
Hi Marcel
I see you're in Cape Town - beautiful city - I first went there in 1962 working on Union Castle ships out of Southampton.
Thanks for the tip re Balsa inserts at the bow, I had been ruminating on that topic after reading several other builds. I noticed Mr Tomic dosn't
use them in the official build.
Thanks for the welcome and from all you other chaps.
JohnP
John Passmore
#18 Posted : 30 April 2014 14:53:45
Tomick wrote:
Hi John,
Hello Mr T
Sorry I didn't get back to you sooner - I've been reading other peoples' builds most of the week and have gleaned lots of useful information.
Wish I'd have read the info (re this forum} in Issue 1 more closely instead of charging straight into the build, there are lots of things I would have done differently. However, luckily my build to date seems to check out ok - nice and straight and square. Can't wait to get to grips with the nitty gritty now.
Couple of quick questions:
When plankings are issued, are there surplus materials in each pack to cater for the errors of absolute novices like me?
I've been studying Mikes'(MWG) build with keen interest - that bloke is absolutely brilliant. His text and photos explaining his methods are so concise and easy to follow, but he stopped contributing October last. Is he not doing SotS anymore?
Thanks for the advice on the display stand and for your message of welcome.
JohnP
#19 Posted : 30 April 2014 19:23:04
BigGrin Hi John to answer your question on the planks you get lots of them . I have 2 bags left over . Hopes this helps rgd Martyn BigGrin
John Passmore
#20 Posted : 02 May 2014 01:26:42
Hi Martyn
Thanks for the info - much appreciated.
JohnP BigGrin
21 Pages 123>»
This page was generated in 0.786 seconds.
