 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
I have just ordered my senna mp4/4 and I can't wait to receive my first pack. Was just wandering what glues I will need in advance. Any help will be appreciated Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Joined: 01/09/2012 Posts: 111 Points: 306 Location: Nottinghamshire
Greetings Steve,
The adhesives required are all covered in the official build diary here
Buy quality modelling adhesives for the CA and polystyrene glues. Its not worth trying to save a pound or two on a model like this. The build diaries have more detailed info on the glues people are using.
Dave
Hi Steve and welcome to the forum. Two types of glue I am using on the official build are GRIP CA glue medium and EMA plastic weld. Spencer
 Rank: Newbie  Groups: Registered
Joined: 01/05/2014 Posts: 4 Points: 12 Location: England
Hi guys, Just ordered my Senna McLaren too. I'm a complete noob at this so wish to get my apologies in now if I end up asking the most obvious questions!
Welcome to ModelSpace, and feel free to ask away..
Hi Mark and a warm welcome to Modelspace  As Tomick say's feel free to ask. Spencer
Thanks guys. My first question is what makes of masking tape, hobby knife and glues would you recommend?
I'm really struggling with these ABS parts where I'm supposed to use the plastic weld. I'm carefully applying and leaving for 1 or 2 hours but it just won't stick. I've made sure that I've removed any painted areas. I'm now having to re-order the 1st pack as I've ruined the decals by over applying and smudging them badly. Why must I use this stuff, why can't I just use the plastic adhesive? Any advice?
Hi Mark Can you supply me/us with a photo/name of product etc of the Weld that you are using as the EMA plastic weld I use give me no problems if applied correctly... If your using the thick pipe weld then this has not been officially suggested to use on the MP4/4 build. Look forward to your reply Spencer
I'm using the EMA Plastic Weld, it's the same one as in the picture inside the magazine which was delivered. I guess I just need to get used to how delicately these things stick. The area you apply the weld to is very small when considering how big the front wing and nose cone are. The glued area to part itself ratio is very small.
Joined: 05/09/2012 Posts: 198 Points: 596 Location: Location
Suprised myself, after not wanting to go through this again after the MP4/23, but ive just ordered mine also...oops
Welcome back
Thanks :-) Ive resisted so so much...but gave in. Having seen some on here and all the ads on TV during GP weekends.
Havent really been gone, just lurking from time to time :-)
