6 Pages <1234>»
Billing Boats Titanic (yep, the big one) Options
DJS
#21 Posted : 16 April 2014 20:02:34
Very nice work, yes the brass tubes that are missing for the prop shaft are supposed to be in the missing parts pack.
Dave
Wieltje
#22 Posted : 18 April 2014 15:51:12
Missing parts kit received. Concerns the missing wood parts 3269L . Nothing else included. (no messing tubes, but in my build this does not really matter)
Wieltje attached the following image(s):
Wieltje
#23 Posted : 27 April 2014 13:55:25
Completing the hull planking. First layer, but remember there is no real second layer. Only a few thin planks adding -undrilled- portholes. The supplied planks are 2 mm thick which is a bit unusual for hull planking. They are rather easy to install and real strong. I do suspect sanding is going to be difficult though because they are rather rough. To get them smooth will take deep sanding (up to removing almost half a millimeter or more at places).
#24 Posted : 27 April 2014 14:00:36
Jen1988
#25 Posted : 29 April 2014 14:55:38
Rank: Beginner Level 1
Great work so far on the model!! It's perfect!
I've just post a question on faves dairy, perhaps you could also help. Here's what I asked,
I'm not sure if you have realized this yet, but I've just painted the forward walls on B deck (parts 78 77 & 76) I figured I would place the window frames on the these parts before fixing them into place. There are 14 frames needed in total for these parts. I've searched through the instructions and have come up with nothing in regards to what etch numbers these particular frames are!? In figure 53 of the instructions, these frames (and a few doors) magically just appear on the drawing, with no part numbers.. I've looked at the photo etch sheet for frames that look like the right fit but those parts are used else where.. Am I missing something here!?
It wouldn't surprise me with this kit, I'm sorry to say but for the high price tag, the instructions are poor and hardly detailed (not one written explanation or colour drawing in the whole thing) and there are missing parts of the kit which we have all had to request from billings. I'm thinking these frames may be another missing part :(
Let me know if you can work it out!
Cheers mate
Wieltje
#26 Posted : 29 April 2014 18:43:57
Cheers mate
Please look at fig. 45. There we see similar windows on another deck. I have a strong suspicion the frames F988/25 are the ones we were looking for. On the sheet you'll find them on the far right. Think there 's 60 of them. I didn't count if that is enough but I would guess it is.
Indeed, instructions are rather poor. I've seen better (but also worse) .
Hope this helps.
Wieltje (my real first name is Willy)
Wieltje
#27 Posted : 07 May 2014 21:26:40
Sanding, sanding, sanding... As you will see in the pictures, even after a first deep sanding she is still far from smooth. Decided to use a filler (because this ship will be painted that's not really a problem) and opted for a very dark one. May seem unlogic but this permits me to see exactly how far I have to sand it down afterwards. Pictures will make clear what I mean. BigGrin
#28 Posted : 07 May 2014 21:37:20
WTG, Drool
Looks great.
One question:
If you have to turn this monster over, how many people does it take?
Wieltje
#29 Posted : 07 May 2014 21:42:34
Time for the 'second planking layer' . Indeed, not complete, but looking at original pictures of Titanic you may have noticed that the real ship also has this somewhat strange hull structure. And then... there's the problem I noticed from the moment I opened the building box. Most portholes are not even intended to be drilled. Don't even think about mounting lights inside or so. And NO frames ! For a static model I needed and found a solution. You will see in the pictures that I purchased some ferrules (for electric wires) and adapted them to become frames. I hope the pictures show how exactly I managed that. The result is pretty pleasing. Think this will do very nicely indeed once the ship is painted .
Wieltje
#30 Posted : 07 May 2014 21:56:55
delboy271155 wrote:
WTG, Drool
Looks great.
One question:
O yeah, turning her over is not easy at all. Risky too, I've broken pieces on several occasions allready. My personal situation - I'm a wheel chair user - makes it even more difficult. So to answer the question... if you have someone in the neighbourhood ... it takes two to turn her over safely Blink
#31 Posted : 07 May 2014 22:00:36
Warthog
#32 Posted : 07 May 2014 22:42:22
Amazing stuff Weiltje Cool your doing a brilliant job on the portholes and must have some patience there!
Great stuff
Spencer
Jen1988
#33 Posted : 08 May 2014 08:46:11
Fantastic work! And great Indra re the port holes!! Your photos (especially during the planking) are better guidance than the instructions!
bianco64squalo
#34 Posted : 10 May 2014 08:20:59
Hi Wieltje,
your hull is fantastic, but i don't know why you decided to make a external rim to portholes: Titanic had not....
Wieltje
#35 Posted : 10 May 2014 13:08:10
[quote=bianco64squalo]Hi Wieltje,
He, this is a bit of a surprise to me. Never saw a picture this detailed of Titanic's hull. Looking at the hull with all the
closed portholes (imagin them painted) is what made me think I needed frames to give it better looks. Goodness, bit unsure
now. Removing the rims is not too difficult yet, but then again, they really do look pretty on the ship...
Wieltje
#36 Posted : 11 May 2014 19:26:53
Since I would like this model to be a Titanic-model and not a "Wieltjes-model" I will indeed remove the biggest frames in the portholes. They are too obvious. The smaller ones will be sanded down to make them barely visible but they still provide a good finish to the smaller portholes. Unfortunately the bigger windows and portholes were mounted with acetatefilms on the inside. Painting them is IMPOSSIBLE this way.
Wieltje
#37 Posted : 11 May 2014 19:34:45
For readers that did NOT yet mount the prefabricated hullparts ( especially 123/124) take notice that you can't paint the windows/portholes if you first mount the acetate. Painting the inside frame without touching the film would demand incredible precision. I have decided to remove these parts from the ship. Then I remove the acetate. Now painting of the inside edge in windows/portholes becomes possible. Only after finishing that paintjob I'll put acetate or other films back in place.
Gibbo
#38 Posted : 24 June 2014 12:15:42
this looks huge, how long is this model ?
Wieltje
#39 Posted : 24 June 2014 12:59:29
She's about 6 feet long (in metric: 185 cm). A bit difficult to handle and a bit of a problem to find a
good place to show the ship. :-)
Wieltje
#40 Posted : 28 June 2014 18:16:31
Time for an update on this build.
First a few pictures off the (partial) second planking layer and the construction of the rudder.
Guest (10)
6 Pages <1234>»
This page was generated in 0.611 seconds.
