Joined: 26/03/2010 Posts: 146 Points: 473 Location: Plymouth
I've just received this toolkit from Drapier http://www.drapertools.c..._skmno=21835&ipadd= 29 PIECE MODELLERS TOOL KIT Stock No: 21835 Part No: HK29 Comprehensive tool kit which can be used by modellers, craftworkers, woodcarvers, etc. Packed in blow mould case with display sleeve. Contents: • 2 handles (8 and 11mm diameter) • heavy duty handle (11mm diameter) • piercing awl • sander • mitre box (138 x 40mm x 30mm) • pair of tweezers • back saw blade • 21 assorted blades ...and no I don't work for the company. I'm sure there are shipmates out there that can find it in the 'Pound shop' for a quid but I think it's a useful bit of kit.Especially the mitre box. See what you think. ArtfulBodger Previous Build: HMS. Bounty
no price? no price on link either. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
http://www.atsite.co.uk/...t.aspx?affiliateID=10050On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Magpie You are a marvel. Anything I buy online from now on I'm going to ask you first. Cheers mate ArtfulBodger Previous Build: HMS. Bounty
Joined: 26/07/2010 Posts: 25 Points: 68 Location: Dunstable, UK
I have bought one of these and found it very useful.
Joined: 22/07/2010 Posts: 8 Points: 12 Location: Widnes
Kit can be found at 9atsite.co.uk £24.19 delivered Regards Pete
Joined: 06/05/2010 Posts: 233 Points: 708 Location: Leigh on Sea
http://www.amazon.co.uk/...-TOOL-29PC/dp/B0002BUKS4H.M.S Victory H.M.S Victory X Section H.M.S Surprise under the bench D-51
Guest (6)
