27 Pages «<678910>»
George1 Build Options
AdamHall
#141 Posted : 09 May 2014 02:44:01
John Passmore wrote:
Hi George
Yes...WA maintaining it's unblemished record of "Wait Awhile"
JohnP
Hi John,
I was able to pick up Issue 9 from my local newsagent in Waikiki yesterday without any dramas. So I am not sure what the problem is in your area. Maybe the inclement weather on Wednesday has delayed delivery to Mandurah?
Adam
George1
#142 Posted : 09 May 2014 02:55:54
Tanna Ted wrote:
Hi George,
Saw your launch. Looks great. BigGrin
At what distance did you separate the two parts. Is there a measurement to saw by, or in your case snip by. I have been looking through builds and posts but have found nothingConfused
Hi Ted BigGrin
You'll find if you glued the angle piece to the stern section as was instructions that the top of the angle piece is within the line on rear of stern that you will eventually need to sand to shape. If you use a saw or snips at the stern cut away right against the base board then cut into the angle piece from the top on an angle from say the middle till you get to bottom of cut stern piece. It should then come away. You'll need a dremel head to cut into the angle piece as your saw will not get in there. You could also perhaps use a needle file to do similar.
As far as rest of separation re rib frames if you look underneath you'll see where rib frames finish and a section with a gap running across. just cut below planking and into that gap so you end up with a little waste on top of rib frames as per my pic of separation. BigGrin
See my pic of separation and you'll see the remainder of the angle still stuck to stern which I have now sanded away with the rest of unwanted material. BigGrin
Hope that is of help to you. BigGrin
George
Building HMS SOTS
George1
#143 Posted : 09 May 2014 02:58:37
jock wrote:
Got issue 9 today or was that yesterday ;-)
Hi Jock.
From what you say it may only have been a problem in John's area. I hope so as we are aware what happened last time. BigGrin
George
Building HMS SOTS
George1
#144 Posted : 09 May 2014 03:00:51
Doing a great job George, well done on the launch it looks like it will sand down very nicely, just take care as the planks are very thin....Cool Cool
Hi Alan.
Thanks for your kind comments. Cool Cool
Yes those planks like tissue paper. They certainly needed careful handling. BigGrin
George
Building HMS SOTS
George1
#145 Posted : 09 May 2014 03:02:50
Hi George
JohnP
Hi John,
Adam
Hi Adam BigGrin
Yes Jock got his too so looks like only John's problem this time.
George
Building HMS SOTS
John Passmore
#146 Posted : 09 May 2014 04:59:08
Publisher Medal: Featured Build of the MonthOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
George1 wrote:
Hi George
JohnP
Hi John,
Adam
Hi Adam BigGrin
George
Hi Chaps
Went to the newsagent this morning and told him you all got your copies so where's mine? With a red face and a flourish he produced it from under the counter! Seems he forgot where it was.
George, I've ordered the paints from Float a Boat. Seems there's a lot of people in Oz doing SotS as Rhonda is snowed under with orders.
Many thanks for the info.
Kind regards
JohnP
George1
#147 Posted : 09 May 2014 06:03:46
Hi John
That's good to hear you got issue 9 ok. BigGrin
Re paints; The other supplier is still out of stock going by their web page and they didn't reply to my inquiry emails so good we got onto Float A Boat.BigGrin
By the way Float A Boat do carry lots of other items regarding planking, tools and accessories. I ordered a plank crimper as well and got it the other day. So if there are other items you night need outside of paints give them a query and most likely they will have. BigGrin
They will eventually have all they carry on their web page so they told me. BigGrin
Pic attached in case you're wondering what a plank crimper is.BigGrin
Only $AU12.95 plus p+h. I got mine sent express post.
George
Building HMS SOTS
jock
#148 Posted : 09 May 2014 06:53:52
George I have in the past steamed my planks, do you find the crimper a better option?
Previous builds
Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour
http://jockspage.webs.com/
George1
#149 Posted : 09 May 2014 08:10:15
Hi Jock.
I really have no idea yet as never used but did see in builds a number of older members used such an item. I can see the way it works so will give it a go when we start planking.BigGrin Or its steam iron.Laugh
George
Building HMS SOTS
George1
#150 Posted : 09 May 2014 08:12:29
Have now sanded off waste and painted inside only. Not perfect by any means but OK.
Glad to say no paint came through planks on outer so well sealed.
George
Building HMS SOTS
John Passmore
#151 Posted : 09 May 2014 11:34:58
Hi George
Your ship's boat is looking really good, I started mine today with a lot of nervous trepidation. I've been checking other peoples' builds for this item and finding the problems and then solutions, so hopefully mine will look as good as yours finally.Cool
I purchased my planking tool from Stanbridges Perth $12,95. They have a good range of stuff, but don't do the Admiralty paints. They do Humbrol amongst others.
Kind regards
JohnP
George1
#152 Posted : 09 May 2014 13:13:37
Hi George
Kind regards
JohnP
Hi John.
Thanks for your comment re my row boat but having the row boat as good as mine won't be very hard. BigGrin
Good you got planking tool locally. I don't get to town much so prefer via postage. BigGrin
Only tools I need now is a set of needle files which I'll possibly get from local hardware store. BigGrin
George
Building HMS SOTS
#153 Posted : 09 May 2014 14:24:46
Hi there George..You've done a really good job on the launch mate!! As for the crimper for the planking,I thought they were great to use if you were second planking...First time I've used the crimper..I used to soak and bend the planks using a soldering iron in the past...Looking foreward to seeing the rest of tour build...
Smile ThumpUp
George1
#154 Posted : 09 May 2014 15:37:10
Hi jonny7england.
Thanks for the kind comments. Cool Cool
I've never used a crimper before so don't know what's best. Just thought I'd get one as seen some builds. If it works OK, if not it's the hot job. BigGrin
George
Building HMS SOTS
#155 Posted : 09 May 2014 23:01:09
Looking good George.... Cool Cool . You see, patience does pay off dividends.... look forward to your next post.... Cool Cool
George1
#156 Posted : 10 May 2014 01:57:29
Hi Alan.
Thanks for your encouragement it is appreciated. Cool Cool
One thing about painting the row boat even on the inside is it seems to make it all feel more solid and less flimsy. BigGrin
George
Building HMS SOTS
George1
#157 Posted : 11 May 2014 03:24:36
By the way regarding glossy finish on row boat interior (not intended BigGrin ) if not wanted easy to use clear matt spray. You can get from art supply stores along with clear gloss spray. Artists find it a real boon because if using oil paints depending on the amount of turps or oil fillers a painting can often end up with parts glossy and others matt when it dries. To get an overall evenness either glossy or matt to suit painting these sprays are used once paint fully cured or dry. It also gives added surface protection where painting can be washed with detergent if fly spotted over time or just dirty from dust. An old painting before and after really shows the effects if these sprays have been used then painting cleaned. BigGrin
George1
Building HMS SOTS
#158 Posted : 11 May 2014 08:06:18
BigGrin Nice tip GeorgeCool
George1
#159 Posted : 11 May 2014 09:33:27
Hi Andy
Yes I should have known having done considerable oil paintings in the past and used such sprays as protective coats and for evenness of either matt or gloss finish.
These days this material which is crystal clear is guaranteed never to yellow or milk up even after 100 years.BigGrin
Happy to pass on tip.BigGrin
George.
Building HMS SOTS
#160 Posted : 11 May 2014 12:09:23
27 Pages «<678910>»
This page was generated in 0.385 seconds.
