Off-cut Hoard Options
Garth
#1 Posted : 09 May 2014 14:24:24
I have also posted these pix in my build blog, here they are again.
Around issue 30, I decided to sort the larger pieces of off-cuts into old part bags. This has proved to be an excellent source of material, especially as the part works have more than enough timber. I found that around issue 90, I was bagging entire lengths of wood and mostly using the off-cuts.
I have also saved the extra blocks, columns and ropes etc.
With SOTS and the Cutaway model on hold – these will definitely come in useful.
Kind regards,
Garth
Garth attached the following image(s):
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
This page was generated in 0.825 seconds.
