Banana Boat. Options
Admiral Langley
#1 Posted : 31 July 2010 20:39:12
Hi all,
After reciving issue No17, i wanted to start building my hull, ive glued all the ribs and keel parts and loose assembled them, (as per the instructions). After placing the first deck on my boat i noticed that it was all out of line. upon closer inspection i found the keel to be bent. i've tried soaking in hot water and leaving over night,(with a brick on it) to dry out,to try straighten them out, a bit better but still bent. How critical is it to have the keel perfectly straight, and can someone tell me how to d it. thanks.
benny
#2 Posted : 31 July 2010 20:56:20
hi..check out zeptraders thread its called "index of topics" and click on "building a jig" and go to post number 14 for a picture...hope this helps
cheers benny
Admiral Langley
#3 Posted : 31 July 2010 21:09:11
Thanks Benny,
Never thought of that,something so simple. Of to the DIY store tommorow.
This page was generated in 0.108 seconds.
