6 Pages «<3456>
ARP's Zero Options
#81 Posted : 16 March 2014 18:04:30
#82 Posted : 16 March 2014 21:12:30
BigGrin Hi Steve
regard
#83 Posted : 19 April 2014 14:17:07
Issue 11 comprises of the wing light wiring ,the second undercarriage leg , aileron hinges and side cockpit instruments/radio/battery box.
The lighting wires were added 1st then the fuel tank to the wing section after that the undercarriage was added along with the gun, lastly the wheel well's were added to the wing.
lastly the battery box/ side intsruments and radio were assembled where needed undercoated then painted up before fitting in position
#84 Posted : 20 April 2014 11:16:05
Hi Andy, looking good..Cool
#85 Posted : 20 April 2014 11:37:48
#86 Posted : 20 April 2014 17:55:30
BigGrin Hi Alan
#87 Posted : 20 April 2014 17:56:47
BigGrin Hi Steve
Certainly a quality kit and build , Thanks for looking in and your comments
#88 Posted : 20 April 2014 18:00:52
BigGrin Lovely work Andy this part work looks stunning BigGrin Rgd Martyn
#89 Posted : 20 April 2014 18:12:52
BigGrin Hi Martyn
Thank you for looking in and your comments
#90 Posted : 17 May 2014 20:57:28
This month its a great deal of panels for the cockpit to paint and fix in position. The left wing also has the flap made up and fitted, the air intake fitted, the upper skins added and the folding wing tip fixed to the wing. The last thing to be made up was the first of the ailerons.
More soon.
#91 Posted : 17 May 2014 21:51:27
#92 Posted : 17 May 2014 23:36:59
Hi Andy, the more I see this build the more impressed I become.... stunning kit and great work..... Cool Cool
#93 Posted : 18 May 2014 07:58:56
BigGrin Hi Steve
Thanks for looking in and your comments. Your right about the cockpit starting to look busy now although all the parts are supplied in cast form and have to be painted so not looking too bad. Im just glad the seat will go in from belowBlink LOL as its getting a bit crowded in the upper parts.
#94 Posted : 18 May 2014 08:02:45
BigGrin Hi Alan
This is an outstanding kit and build goes together like a dream unfortunately it is now no longer available here. Thanks for looking in and your comments
#95 Posted : 22 June 2014 20:57:15
Another instalment on the build. The first thing to do was to make up the second aileron, this one will be covered in nylon and painted silver to reflect the silver dope used on fabric coverings of the period.
Then next thing was to add the high tensile leads and spark plug leads to the engine and make up the engine mount.
A very simple but clever and nifty jig was provided to start the build of the rear fuselage I will be painting this after all the former's and stringer's have been added.
Finally the radio tray was made up and fitted as was the aileron tab adjustment wheel in the cockpit then the outer cover for the spent shells ejector unit was added. More soon
#96 Posted : 22 June 2014 21:27:16
Hi Andy, BigGrin
Some lovely work going on there. Cool Cool
I`m gonna have a wealth of info when I start mine in the future.
Thanks for some easy to follow pics and info. Love
#97 Posted : 23 June 2014 21:27:34
BigGrin Hi Del
Warthog
#98 Posted : 23 June 2014 22:01:21
Coming along nicely Andy Cool Very nice indeed Drool
Spencer
#99 Posted : 23 June 2014 23:50:26
BigGrin Hi Spencer
#100 Posted : 22 July 2014 20:04:47
Some more done on the Zero.
The rear fuselage has been made up with all the stringers now in place and sprayed with Aotake and the fuel tank and oil tank sprayed with Aotake, the fuel tank has been fitted but not the oil tank as yet.
The rear part of the engine has been painted and added to the engine mount and finally the deceleration chamber has been painted and added to the propelor assembly.
More soon
6 Pages «<3456>
