 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
In the instructions each stage shows all the parts and some plastic parts are labelled as abs and some don't say anything. For example stage 1 has abs next to the wing and nose but nothing next to the lower and upper noise boxes. Is this because it's a different plastic? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Hi Steve The other unlabelled parts will be HIP's (high impact polystyrene) given that the model uses ABS,HIPs, metal and rubber parts. Spencer
So the caliper and disc in stage 3 are This material then. So I assume the hips glue will need to be used for these then? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Process of elimination would suggest that yes
