abs or not Options
Steve279021
#1 Posted : 26 May 2014 16:28:59
In the instructions each stage shows all the parts and some plastic parts are labelled as abs and some don't say anything. For example stage 1 has abs next to the wing and nose but nothing next to the lower and upper noise boxes. Is this because it's a different plastic?
Dodge charger build complete
Warthog
#2 Posted : 26 May 2014 17:00:43
Hi Steve
The other unlabelled parts will be HIP's (high impact polystyrene) given that the model uses ABS,HIPs, metal and rubber parts.
Spencer
Steve279021
#3 Posted : 26 May 2014 19:43:30
So the caliper and disc in stage 3 are This material then. So I assume the hips glue will need to be used for these then?
Warthog
#4 Posted : 26 May 2014 20:00:38
Process of elimination would suggest that yes
This page was generated in 0.261 seconds.
