HMS Warrior Research Photo Walk Around. Options
#1 Posted : 29 May 2014 22:49:11
Yesterday I spent 2 hours taking over 350 pictures primarily of the top deck of HMS Warrior. This is the start of my research and reference materials for a new project I am planning for around 18 months time, The Billiangs Boats HMS Warrior kit, yes the 'other big one!'BigGrin
Soon as I get the kit I will do a full review. in the mean time over the next couple of day I will be posting my my research pics in this thread with some commentary.
Deck
I have started with the deck because it highlights the the caution required when researching a model build. I was fortunate to get chatting to the chap responsible for Warriors maintenance and the curator on the ship.
The deck on Warrior currently is the second deck to be installed since Warriors renovation. originally Warrior would have had a fir deck planks but the current decks are teak because they are more hardwearing. The lay of the deck timber is not correct as the deck has been laid for the most economical use of material not for historical accuracy. The caulking is not real either its rubber strips. the deck does not butt up to the splash way as it should because a gap has been deliberately left to let the deck breath and finally there is no visible sign of fastening, tree nailing or otherwise. The original deck would have been fastened to iron beams. but this deck is glued to a sub-stright to keep it in place and stop warping etc (the same method used for the Cutty Sark). I have already seen a model built where the modeller in all innocence as done their best to emulate the deck as she is, thus not getting it historically accurate. First rule in research, if its not a primary sauce then cross reference as much as possible.
In this first picture you can see how the deck planks have been butted up with no visible fastening and only caulking on the length not the ends. The deck colour will be wrong so some reference material on fir decks is required.
In this pic you can see the gap between the deck and the waterway. The scupper grill is not flat but crescent shaped, a nice detail to get right on my model. Although Warrior was clad in iron this sandwiches teak. Scuppers up to the 19th century tended to be lead lined and it looks like this may be the case on Warrior.
Just because we know the deck material is wrong does not mean we have to dismiss everything. In this picture we can see the pike rail extends well beyond the row of pikes around the command tower base meeting the hatch coamings. another nice detail to capture.
I will be posting more soon as I get the picks into photo bucket.
mark 2
#2 Posted : 30 May 2014 06:44:07
Hi Jase.
Hope your family and yourself are well.
Thank you so much for sharing these pictures with us BigGrin .
I for one am looking forward to your build of this iconic ship and i know that you will do a perfect representation of Warrior.
Very best regards.
#3 Posted : 30 May 2014 07:23:10
mark 2 wrote:
Hi Jase.
Very best regards.
Thanks Mark. I have wanted to build a model of this amazing ship for many years, I have no idea why she has been overlooked by by every kit manufacturer she is such great looking ship
J
#4 Posted : 30 May 2014 08:24:36
I will start the walk around amidships on the port side moving forward then down the starboard side to the stern and back up.
The first thing that strikes you is that once you are on deck you can not see out to sea. The bullworks are solid and extend to about 7 foot at a guess. the only vantage points are two entrance gaps on each side and a small number of gun ports. otherwise there are two bridges. There is a small number of gun ports on the top deck and interestingly theas open by dropping down, being hinged at the bottom. We can see the retaining chain on this example and two eyes for rope, it is not clear to me yet how this was lashed back.
There is a single Sheave block in the bulkhead as well as two large eyes to the left of the gunport,
Hear we can see the shape of the waterway. As said before this should butt up to the deck plank.
There are a number of these iron plates on the deck I believe, due to there locations, that they must have been used for lashing down the cannons in conjunction with the eyes mounted on the other side of the gun port.
The rigging blocks are all hidden in the bullwork tops. This pic gives me the moulding shape, and a sense of proportion.
A close up of one of two booms? cast iron, again some nice detail to capture If i can confirm these were stowed like this.
Again not sure how original this feature is but all the bullwork planking is bolted into place. I am pretty sure metric hex bolts were not used, but if this feature is correct it could easily be captured with use of a drill bit.
This pic is interesting as it shows pudding of the shroud.
Base of the main shroud
This pic of the capstan shows the base being bear wood, an important detail easy to miss. The centre point is brass I will need to use the many pics on the net as further reference.
This is the conning tower. Because Warrior's two bridges were open this armoured tower gave the ships officers protection when in battle. The Ports are for viewing events, I guess not the best visual arraignment! We can see the boarding pike storage arraignment and the large beams that the open bridge is mounted on. you can also see the business end of the capstan bars which are stowed under the bridge.
This pic shows the capstan bars more clearly. we can also see the rope trim on the base of the bridge which is wood but I guess would have been cast iron. We can also see the mounting points for the bridge rails.
#5 Posted : 30 May 2014 11:35:18
Great pic's, thanks for sharing ThumpUp
#6 Posted : 30 May 2014 21:33:37
There are a number of skylights running along the length of the ship, for some reason this set has metal grates covering them. not a feature on the others that were uncovered.
There are a lot of vents on Warrior. The little detail on the side is just the sort of thing a kit may exclude but easy to replicate yourself.
Some seriously good looking bits at the base of the main mast. lots of brassDrool Easily one of the deck focal points on a model.
#7 Posted : 30 May 2014 22:39:45
Looks like you had a fab day on this ship Jase and its great to see your research pics.... Going to look forward to seeing you build this beauty... Drool Drool
#8 Posted : 31 May 2014 00:57:11
Thanks Alan, Like I say a bit off yet a lot of research to do and some projects to get out the way.BigGrin
John Passmore
#9 Posted : 19 June 2014 08:43:20
Publisher Medal: Featured Build of the MonthOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Hi Jase
Some really good pics of the deck detail. Brings back nice memories of my visit to the Warrior in 2010 - even though it was freezing cold, blowing a gale and raining, but I was fascinated by this historical ship.
A detailed model would be a real challenge. I wish you luck.
JohnP
#10 Posted : 19 June 2014 13:49:01
Thanks John,
I dio have some more pics to post stern, hull main gun when i get a moment
This page was generated in 0.082 seconds.
