steven.b Options
steven.b
#1 Posted : 30 May 2014 12:45:31
Hi guys,
Have just fitted the ten beams for the deck - have noticed they are a bit "bouncy". I was wondering if I cut 20 mm posts from the waste die and position them under the centre of each beam would they interfere with anything later in the construction, appreciate any feedback
#2 Posted : 30 May 2014 13:07:25
BigGrin Hi Steven
The beams will be like that untill the decks are placed and glued on top then all should become quite solid
KymMareeAU
#3 Posted : 30 May 2014 17:46:57
Hi Steven.
Would that be Issue 12? I am not up to that point myself, however i think i read someone has put a balsa support every second beam.
So i would think it wouldn't interfere with anything later if you did.
Kym :)
Current Build : HMS SOTS
steven.b
#4 Posted : 31 May 2014 09:41:20
Thanks guys,
yes Kym, issue 12 - I think I might try the posts, I'll let you know how it went
#5 Posted : 31 May 2014 09:55:34
Hi Steven, adding additional supports under the beams will strengthen the deck and will not be seen... I added two pillars under each cross beam, didn't cause me any problems and am pleased I did... I now have nice sturdy decks....Cool Cool .. Keep up the good work, will be following your progress...
This page was generated in 0.269 seconds.
