23 Pages <1234>»
HMS Surprise build log (Robert) Options
hudsonrobert49
#21 Posted : 25 May 2010 15:26:19
Just a little up date.
Rob
Bridlington.
hudsonrobert49
#22 Posted : 25 May 2010 15:37:11
Hate Cameras, Just a light sanding, and my nailing looks crap (well on camera)Cursing , not great though.
The planks are stuck firm.
Rob
Bridlington.
hudsonrobert49
#23 Posted : 20 June 2010 09:44:19
Quick up date of pic's
Still NEEDS MORE sanding
Rob
Bridlington.
hudsonrobert49
#24 Posted : 20 June 2010 09:46:51
I need a lot more info on how much and where to cut the sides and the back end where the cabin goes.
Rob
Bridlington.
hudsonrobert49
#25 Posted : 20 June 2010 10:18:17
Both my Builds together
Rob
Bridlington.
hudsonrobert49
#26 Posted : 20 June 2010 10:19:52
Rob
Bridlington.
#27 Posted : 20 June 2010 23:58:30
Looking good now there. Starting to take shape now.
Keep up the good work..BigGrin BigGrin BigGrin
snowtiger
#28 Posted : 21 June 2010 14:41:52
Thats looking realy good Rob.BigGrin ...and it's big..Drool ..i have seen smaller boats in whitby harbour...BigGrin BigGrin
Capt Stedders
#29 Posted : 11 July 2010 23:38:54
Looking very tidy there HR, it all looks very clean and neat - keep up the good work.
How are you finding the planking?
Schnellboots on back burner
Tools.
ajbird74
#30 Posted : 02 August 2010 14:08:14
Hi
Could you please advise how you have decided to fix your planking on the hull - have you just glued were each plank contacts a rib or have you glued right along the edge of planking strip so that it fixes to the next strip added.
this has been one of my concerns with single planked ships as I am worried that when cutting out the gun ports some of this planking may "shift" if its not been glued to its neighbour.
Kind regards
Tony
#31 Posted : 02 August 2010 14:33:20
Hi Ajbird74
The best way and strongest is to Glue along the length of the planks and onto the rib. So when you come to cut out the Gunports there will be plenty of strength. I also where i can get to it and if not being stained, brush some glue behind the planks to be cut for the ports. It may not always be easy to get glue behind but if you can it helps.
Hope that helps.
Chris...
hudsonrobert49
#32 Posted : 03 August 2010 07:57:04
Hi I glue the planks to the ribs and along the edge.
Rob
Bridlington.
smichc
#33 Posted : 04 August 2010 22:15:05
looking good .. like your build alot
LETS BUILD AND BUILD
HMS VICTORY
HMS SURPRISE
Can you help me with the volturno
Eccles
#34 Posted : 05 August 2010 19:17:31
Rank: Beginner Level 3
Your freeboard planking looks really nice Robert! I love the lines!
I've recently moved into my first new house so haven't had a second to do any work but now I think I'm ready to get back to work!
Quick question if you don't mind, can anyone tell me what parts they received in issue 5 and 6? My parts don't seem to match the instructions.
In part 5 I received only a bundle of basswood planks for the freeboard planking and the inside of the bulwarks. However, the instructions for issue 5 tell me to construct the "cradle" but these parts weren't present.
However, when I received installment #6 I got only the pieces for the cradle. The instructions for issue 6 are for planking the hull with the sapeley planks...no sapeley planks in installment 6 though!
Is this the same for everyone else...or is there a mistake with my order?
Thanks,
Jonny.
hudsonrobert49
#35 Posted : 06 August 2010 07:31:10
Forgive the Pun but I'm in the same boat, that's exactly what I got, don't know why I got all them extra planks for as I DON'T KNOW WHERE THEY GO????.Confused Confused Confused
And yes my instructions are all back to front!, and the instructions are all crap, with me it's mostly guesswork.Cursing Cursing Cursing
if I have any tips I will let you know.
PS got any pic's you guys.
PPS thanks for the complements.
Rob
Bridlington.
#36 Posted : 06 August 2010 08:33:52
Hi Rob,
What I've been doing is following James pics on picasa of the build he did to find out if things where looking in the right place(Yep the insructions are Crap..). The extra planks youv'e got sound like they have given you the ones for the inside of the top deck.
Thanks Chris...BigGrin
http://picasaweb.google....mail#5235290510112630658
hudsonrobert49
#37 Posted : 06 August 2010 09:22:44
Yep I'm following James Ch.
Rob
Bridlington.
#38 Posted : 07 August 2010 23:03:27
Hi Rob,
Did you have any problems with the ribs not leaving the planks straight. I've posted pics on my build of my problem . please could you advise how you got yours straight.
Thanks Chris....
Eccles
#39 Posted : 08 August 2010 11:17:22
I see you've had the same confusion with the instructions that I have...
It specifically says to not trim the excess of the planks at the stern, but in the next set of instructions they have been trimmed and shaped! Are you going to wait until you have the instructions and parts for the grand cabin before doing any shaping? That's my plan I think.
I'm having some trouble with my first few planks at the stern actually. Did you have to do any shimming to frames 14 and 15? At the moment my planks don't get anywhere near them and I'm worried that if I try and bend them to lie along these frames they will point inwards and not allow room for the cabin? I hope that makes some sense!
Cheers,
Jonny.
hudsonrobert49
#40 Posted : 08 August 2010 11:59:55
no i have not done any shimming, i will post pics soon.
Rob
Bridlington.
Guest (6)
23 Pages <1234>»
This page was generated in 0.188 seconds.
