 Hi Martyn Thanks for looking in,hopefully il be able to build her with the minimum of paint if at all regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 16/03/2014 Posts: 516 Points: 1,563 Location: Perth Western Australia
Hi Andy Will be certainly watching your build with interest. Looking tops so far. Regards George Building HMS SOTS
 Hi George Thanks for looking in and your comments very much appreciated Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
think this is on my wish list good and proper now “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Jase Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, What a great build this is, love the second planking this looks a bit bigger than the Victory excellent build Andy Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Hi Trev Thanks for looking in and your comments. The Trinny is not quite as long as the Vic but is a little taller, I think she may look bigger because of the four decks. She is an enjoyable build with the good hard woods included and has gone together without ant major problems. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Finally the lower planking is done  and as you can see if you use all your offcuts where possible there is a goodly amount of planks left over . I have sanded back the white upper deck and will start on the lower deck tomorrow when the glue is fully cured. I have followed the instruction's to do the secondary planking as it was done in a different way to my usual planking method and I must say it worked out fine although I will probably carry on with my usual planking method from now on. There is still some trimming to do around the false keel area at the bow and stern . That just about concludes this month ,more soon Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks fantastic Andy, I know you are leaving this one natural but what kind of finish will the walnut have, varnish, oil etc? Steve
Looking good Andy....
very nice Andy “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Steve Thanks for looking in and your comments. As for the hull finish im not sure yet the decks have been coated in Danish Oil so I wont be using that on the hull maybe a satin varnish or shellac we will have to see Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Alan Thanks for looking in and your comments Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Jase Thanks for your comments Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The hull has now been sanded back and the edges trimmed back ready for the keel to be fitted. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
A finish certainly worth showing off there Andy, this is going to look so good when you get something on it to bring out that grain Steve
Hi Andy, This will look a bit special when finished Andy nice work again. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Hi Steve Thanks for your kind words and comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good
 Hi Trev Thanks for looking in and your comments there always appreciated. There's a little more to add to the upper hull before I can get some seal on the wood to bring out the grain and colour. IF you have a look at Steve's build diary he shows the Triny in front of his Vic build which gives a good idea of the size of both Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (36)
