3 Pages <123
A Tribute to HMS Illustrious - Some Information required please. Options
#41 Posted : 08 June 2014 20:25:20
Thankyou for all the info Jase, good of you to give such a detailed reply. I like the idea of cleaning and priming as I need it too.
As for the build start....well I'm on the verge of starting a separate diary any day now, all other plastic kits are now on hold, Lusty is coming - watch this space as they sayLOL
#42 Posted : 08 June 2014 20:39:31
Hi Steve, Drool Drool Drool Drool Drool
Bring it on can`t wait. Cool
Lusty rules Love Love
#43 Posted : 09 June 2014 10:49:35
Thanks for your support Del, Def be starting this week and will be glad to have you along.
Just one more question I promise, I test sprayed some humbrol paint yesterday - horrible experience. I have no problems with Tamiya at all.
I am test spraying the main hull colour to get a pre-mix made up ready but it just wont spray, the paint is very thick for a start and when mixed with humbrol thinners at 50/50 it is still too thick and clogs the airbrush (tried water mix too). Then adding more thinners eventually sprays but it's like waterAngry
So, anyone else used humbrol acrylics? If not anyone know it there is an exact replacement for humbrol 127 ghost grey in Tamiya range?
#44 Posted : 09 June 2014 14:17:40
I don't rate the Humbrol acrylic range. Tamiya XF19 sky grey is their equivalent.
#45 Posted : 09 June 2014 19:55:25
Hi Steve, BigGrin
Only sprayed Humbrol with an average result and only once. The official Sots set, with what looks to me as a novice sprayer a pretty good result.
Tamiya on the other hand, I`ve done quite a bit as a base coat with the flat range and it`s Cool Cool Cool .
I concur with Mr T, (even as a novice sprayer), Tamiya has given me my best results.
Hope this helps.
#46 Posted : 09 June 2014 20:32:15
Also Velejo Air light grey (which is pre mixed for air brushing and White Ensign Models AC RN 13 Sky Grey Enamel are like for likes too
J
#47 Posted : 09 June 2014 23:58:20
Thanks Guys,
I will try the Tamiya then.
@Del - A lot of people on various forums have been moaning about the humbrol paint too.
Like the idea of the pre-mixed paints too Jase, might look into these also, saves messing about.
OK, some ideas please before start - take a look at the pic below and let me know the best way of achieving this, possibly even with a light on the harrier too
#48 Posted : 10 June 2014 05:21:15
Two thoughts from me
Silver coloured wire or clear plastic sprue join the tail to the deck
#49 Posted : 10 June 2014 20:40:22
Thanks Jase, I think the clear sprue may be good, could be heat stretched very thin, not sure how bendy it would be though as I want it a bit longer than the above pic suggests - more like the one below with a bit of distance between the deck and the plane. Maybe a light on the plane is a bit ambitious then?BigGrin
#50 Posted : 10 June 2014 21:26:45
not sure if this is helpful? you could easily mount a helicopter hovering above deck. and some look hollow so you might be able to get a light up to simulate after burn?
http://www.homecrafts.co...clear-acrylic-rods-m821i
#51 Posted : 11 June 2014 18:12:30
#52 Posted : 11 June 2014 18:30:50
stevie_o wrote:
Those hollow 3mm rods look usefulBigGrin the possibilities are endless, harriers taking off, hovering etc etc, so much to think about!
Hi Steve, BigGrin BigGrin
Those rods do look really good. Cool Cool
Don`t forget, you could be digging a deep hole. LOL LOL
Sure, you can deal with the additional items, "that may come along" and I can`t wait to see more now.
Drool Drool Drool Drool Drool Drool
A flight deck with Helo`s and Harriers taking off.
Seriously Cool Cool Cool Cool Cool Cool Cool Cool Cool
Bring it on,
Happy Building.
#53 Posted : 11 June 2014 22:16:43
Nice ideas coming along Del!!Blink
The rod idea seems the best I think and you could run a very thin optic up to the plane.
One thing I've noticed is when the harriers take off there's quite a bit of spray created if the deck is even a tiny bit damp, you could mask the rod to some extent with some very fine cotton wool or similar between the rear of the harrier and the top of the ski jump?
(or dump a mug full of scenic water over the deck and then you can get away with anything!!BigGrin )
Great plans in the making here!
#54 Posted : 12 June 2014 11:46:31
BigGrin Thanks Del, It does sound a bit ambitious dosent it! All just ideas at the moment which is what this post was for anyway, thanks for looking in.
@Robin, some nice ideas again to add to my confusionLaugh Thanks for looking
Build diary will begin later tonight or tomorrowBigGrin
#55 Posted : 12 June 2014 16:08:46
Anyone reckon this would look cool too! Not so easy to do thoughBigGrin
I'm sure I once saw a diorama of Pearl Harbour though with all the ships and some aircraft flying over, can't find it again to see how it was done!
3 Pages <123
