32 Pages «<56789>»
tf64 Spitfire Build Options
#121 Posted : 02 June 2014 23:45:07
Hello Alan,
It is great to see some progress on the Spitfire as I am sure It will be a great build, it is a shame that there are not more build diaries but I will do my best and keep sending,looking forward to pack 10 now.
Trev.
#122 Posted : 03 June 2014 22:12:04
Hello All,
Well pack 10 has arrived today it seems a long time to wait may be it's me this is such a good build. I have posted some more pictures as promised this is Pack 10.
Issue 36.
Tail fin flap
Wooden strips 2x5 300mm
Brass wire 0.5 mm
Plastic tube
Issue 37.
Fuselage reinforcements fret
Wooden strips 3x3 300mm
Wooden strips 4x4 300mm
Antenna.
Issue 38.
Fuselage side reinforcements
Wooden strip 3x5 300mm
Issue 39.
Fuselage side reinforcements fret
That's Pack 10 by the look of it I think I will be posting about mid month anyway looking forward to the build,( oh! no lighting sent)
Regards to all
Trev.
#123 Posted : 11 June 2014 18:55:46
Hi All,
Pack 10.
Stage 37.
First job was to remove the piece with three holes from the fret and test fit before gluing, this was a good fit in my case and just need a light sanding and glued into place as shown in picture( 1 )what I did find it was that it made a better fit by filing a chamfer top and bottom much the same as you would planking a hull, as shown in picture 2.
This picture shows a file chamfering top and bottom as you would planking a hull.
This picture shows the shorter piece glued and in place just slightly proud of the frame ready for sanding.
Next was to fit the longer piece, this was much the same as fitting the short fret, you may find that it is necessary to sand down to fit when your happy glue it in position. This fits on top of the wooden strip and the fuselage.
Next part was to remove the two fret parts and lightly sand them down.
[/URL
The first piece has to fit above the shorter reinforcement fret and against the main frame fuselage.
The last remaining piece has to fit over the longer piece of fret and up against the fuselage just proud ready for sanding.
This picture shows both pieces of fret in place.
[URL=http://s1134.photobucket.com/user/tf64/media/DSC_5794.jpg.html]
More to follow soon.
Regards to all,
Trev.
#124 Posted : 11 June 2014 19:05:27
#125 Posted : 11 June 2014 20:07:38
Hi Trev, BigGrin
Looking good M8, Cool
It`s nice to see a bit of shaping coming into the build now.
Will be coming back to my Spit build in the very near future, as now have all parts for the second wing`s main construction.
Keep up the good work, will be following with great interest.
Love Love Love Love Love
#126 Posted : 11 June 2014 22:27:05
Lovely work Trev, can see the lines of this beautiful aircraft starting to show..... Drool Drool .very well done...Cool Cool . Look forward to the next instalment....Cool Cool
#127 Posted : 12 June 2014 08:20:24
Hi Steve,
Thank you for looking in on my build and your comments, as you say this will be worth watching as it is a great kit to build. I think when Derek starts his Spitfire build for me that will be worth watching as like yourself he is a very skilled builder.
Trev.
#128 Posted : 12 June 2014 08:27:25
Hi Derek,
Thanks for looking, as you can see the build is moving on now and I have more to add in a few days, like yourself I to have other builds on the way which I will post, yes a plastic 1950 Javelin 1/48 the new airfix kit.
All the best Derek.
Trev.
#129 Posted : 12 June 2014 08:38:10
Hi Alan,
Your comments are very welcome thank you, when I stand back and take a look at the build with the wings in place I can start to see (as you say) the shape, and it helps to keep in mine what I am aiming for and I am sure that's the reason that your Sots has turned out so well.
Warm Regards
Trev.
#130 Posted : 16 June 2014 21:47:49
Update Pack 10.
Stage 37.
First job was to remove the fret with 3 holes, after sandpapering the ruff bits off I test fitted to the fuselage I found in my build very little had to be sanded off it was a good fit.
1st picture shows fret with 3 holes.
2nd picture shows fret in place.
Stage 38.
The next job was to remove the two pieces of fret that hold the small and large fairing then glue them together at 90then if all ok glue in place behind the piece with 3 holes.
This picture shows a small piece of fret (yellow arrow ) this has to be glued Port and Starboard. This is to help with reinforcement, test and fit the small fret and glue in place.
Next was to fit the large fairing (same side as the small piece)now this is the tricky bit, what you have to do is follow the curve of the fuselage, how I did it was to Glue and clamp the thick end and pin the thin end. You must take care with this part the pins I used were like the pins you get when you plank a hull.
What I did find I had to shape a small chamfer at the large end to get the correct angle this may be just my build but it left a small gap which I filled with left over fret.
The next job was to fit the small fret very much the same as fitting the large, here are a few pictures to show.
Now to fit the 3 small pieces of fret to complete this stage, you may find that a little adjustment will be necessary if you can follow the angle of the Fairing in my case the holes were drilled at 90 so I will have to adjust at some point.
Well thank you for looking at my Spitfire build and the pictures, I do hope you find them as interesting as I find this build.
Kind Regards
Trev.
#131 Posted : 16 June 2014 23:11:46
BigGrin Hi Trev
That's a clever use of brass nails to get the curvature of the former to follow the line of the fuselage. Top work as always.
Andy Cool
#132 Posted : 17 June 2014 22:38:06
Hi Andy,
Do you know that fret was so hard I had to sharpen the pins up, so it is a solid old build, still it worked that's the main thing, and it may help others who are in this build, anyway up to date with the Spit now waiting for the next pack, I think things will start to move a bit now as I have a lot of bits waiting, so on to the Vic now.
Trev.
#133 Posted : 17 June 2014 23:36:36
Trev, the more I see of your build the more I am tempted..... problem I have is having nowhere to display the finished build..... Blushing Blushing .. Keep the great work coming....
Warthog
#134 Posted : 20 June 2014 22:30:09
She's looking great Trev and going to be a beast once all the major parts start going together.. Great job ThumpUp
Spencer
#135 Posted : 21 June 2014 08:42:12
Hi Alan,
I know the problem so very well, I would like to buy more but a bit short of modelling space myself, thank you for looking.
Trev.
#136 Posted : 21 June 2014 08:52:55
Hi Spencer,
Glad you looked in, as I have said before this is a great build for both those that are new to modelling, and those that need a challenge, but all very well explained by Mr T. thank you for looking.
Trev
#137 Posted : 21 June 2014 19:40:21
Hi Trev, BigGrin
Lovely stuff, Cool Cool
Like the descriptions and ideas for fixing, WTG.
Keep the pics and build ideas coming, just don`t patent them.
I wan`t to use them later.
LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL
#138 Posted : 21 June 2014 21:00:30
Hi Derek,
Thanks, I know you are very busy with other builds but looking forward to seeing you Spitfire build at some point.
Trev
dandare
#139 Posted : 21 June 2014 21:41:47
very fine work there Trev
enjoying watching your build progress
Dan
#140 Posted : 21 June 2014 23:55:31
Hi Dan,
Thanks for having a look at my build,it's just starting to shape up now I was very tempted to start the Zero then I saw the Spit was available so I went for that, looking at your build Dan it appears to be more complex in metal than wood,but a wonderful job you have done with your Zero.
Trev.
Guest (6)
32 Pages «<56789>»
This page was generated in 0.259 seconds.
