27 Pages «<1314151617>»
George1 Build Options
George1
#281 Posted : 19 June 2014 06:59:37
Issue 15 came today. Now assembled and glued together.
Part on ship is only dry fitted for look. BigGrin
Those still to make, you might find you'll need slight filing of notches when fitting the two curved struts. I did, you might not.BigGrin
George
Building HMS SOTS
AdamHall
#282 Posted : 19 June 2014 07:22:11
Hi George,
Great work to date on the launch. You are certainly paving the way. Well done.
I've not used an optivisor, but as a suggestion you may also want to consider a range of desk mounted magnifiers with built in lights that are used for needlework. Size and types vary according to your budget. You can also get attachments for floor mounting (on wheels) but these are at the top end of the price range. I know of a place locally in Victoria Park that sells them. You can also try online. Have a look at the Scissorman. Daylight Company seems to be one of the main suppliers, but I'm sure there are others as well.
I use a magnifier that has a doughnut shaped fluro. The bonus of the magnifying lamp is that the casting of shadows over the work piece in your hands is virtually minimal. There is also minimal heat radiating from the lamp. There is a protective covering so that you cannot damage or touch the fluro. The magnifier does tend to fog at first on very cold days / evenings when you breathe over it, but this goes away after a few minutes. (Makes for a good birthday / Fathers Day present - possibly?).
Just thought I would put this to you as an alternative for consideration, if you have not done so already.
Adam
George1
#283 Posted : 19 June 2014 07:33:36
AdamHall wrote:
Hi George,
Adam
Hi Adam. BigGrin
First thanks for your kind comments very much appreciated. Cool Cool
Regarding magnifier with light. Yes that's certainly what I'm after. A desk top type will suit or a really good optivisor. I will contact the Companies you mentioned and see if they have a catalog range they can email me. BigGrin
I certainly need something in a hurry.Laugh
George.
PS tried to PM you and Brex on your PM's re planking Float A Boat, but all coming back to me as messages. Won't let me delete George1 from Who To.BigGrin
George
Building HMS SOTS
bb1949
#284 Posted : 19 June 2014 10:02:28
Hi George. BigGrin
Wow that's a big structure and of course looking very good as usual.
I tried the PM and it seemed to let me send you one. If you find it works and is discrete I will add my email address etc.
Brex
George1
#285 Posted : 19 June 2014 10:12:14
bb1949 wrote:
Hi George. BigGrin
Brex
Hi Brex. BigGrin
Thanks for compliment appreciated.Cool Cool
Yes I recieved your PM and have replied.BigGrin
George
Building HMS SOTS
bb1949
#286 Posted : 19 June 2014 10:54:47
Ok sounds great will check the PM in a moment. Also found http://www.northeasterns...r%20NESL%20-%20Copy.pdf
which is worth a look and the Model Rail Road Craftsman at Blacktown NSW still operates and is a stockist but not sure what is stocked.
bb1949
#287 Posted : 19 June 2014 10:57:12
Hi George, Sent a message
George1
#288 Posted : 19 June 2014 11:44:15
Hi Brex. BigGrin
Deleted previous as words misspelled but not by me. Cursing
Highlight the list and copy so you have permanently. BigGrin
George
Building HMS SOTS
bb1949
#289 Posted : 19 June 2014 13:52:04
Many thanks George. Will do. Don't you just love the Gremlins!
bb1949
#290 Posted : 19 June 2014 13:58:45
Hi George I just got onto the web site for Float a Boat and went to the April 2014 newsletter out of curiosity and found an article about the blocks (2nd page). They look very impressive and I would have gladly used these on previous models. I think they are worth a second look. I like them!BigGrin
George1
#291 Posted : 19 June 2014 15:03:08
Hi Brex. BigGrin
I agree entirely regards the blocks. They look fabulous for model ships. Probably will purchase when we get to have to make them up. You can get from 1 to 3 rope channels with them. And already coloured. BigGrin
George
Building HMS SOTS
John Passmore
#292 Posted : 20 June 2014 05:40:14
Publisher Medal: Featured Build of the MonthOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Hi George
I see you got the stern assy together and as mine, there was no need for the little packers at the joint of the struts 45 and upper deck piece 42.
The struts were a bit tight but I managed to get them together without filing. Your ships boat looks great, I'm doing mine the same colour but haven't got around to it yet. I just received the paints from Float-a Boat, they had a bit of trouble with FEDEX. Yes Float-a-Boat has a good website, I'll be making more purchases from there.
JohnP
George1
#293 Posted : 20 June 2014 05:57:47
John Passmore wrote:
Hi George
JohnP
Hi John. Thanks for compliments. Cool Cool
Yes Float A Boat has lots of other items like planking if you decide later to change colour of planking supplied if you had ideas of staining hull later. I'll PM you a list of relevant planking you can get there. Just highlight and copy for your records.BigGrin
George
Building HMS SOTS
George1
#294 Posted : 20 June 2014 08:53:21
Hi .BigGrin
If any of the experienced builders look in like Alan, Karl, Andy, Mike, Jonny or anyone else could you kindly answer my query below;BigGrin
Regarding the brass mesh that goes in bottom of launch after blackening re Burnisher do these pieces have to be shaped at all. I can't see any templates.Confused
The pieces as issued fit into the bottom of the launch OK but encroach on the foot boards by about 10 mm both ends when other ends in position.
I noted in Tomick's Official Build Diary SOTS they appear to only encroach on foot boards about 5 mm and look like there's been some cuts from sides of mesh as well.
Any help greatly appreciated as I want to glue into place once blackened. BigGrin
George
Building HMS SOTS
#295 Posted : 20 June 2014 10:16:45
hi george,yes the brass mesh will need to be trimmed,I used a pair of scissors to trim, because of the slight differences in the building of the launch, some lee-way has to be allowed. hope this helps you.BigGrin
George1
#296 Posted : 20 June 2014 12:48:41
Hi Karl. BigGrin
Thanks for coming to my aid again. It is greatly appreciated. Cool Cool
I will look again at Tomick's build re mesh and try to trim to the same shape as he has in bottom of launch.BigGrin
George
Building HMS SOTS
#297 Posted : 21 June 2014 22:45:02
Looking good George, taking shape very nicely.... Cool Cool
George1
#298 Posted : 22 June 2014 02:18:11
Hi Alan. BigGrin
Thanks for looking in and your kind comments, they are as always appreciated. Cool Cool
Yes, with assembly piece at stern it does start to look like it's finally coming into some shape. BigGrin
George
Building HMS SOTS
George1
#299 Posted : 22 June 2014 04:33:34
Have now burnished and glued in mesh in bottom of launch. Not perfect but OK.Milky look bit only camera flash effect. doesn't appear visually.BigGrin
Also painted bottom of launch ivory white. Needs slight touch up stern corner. Angle of Photo makes keel look twisted, it isn't and is quite straight. BigGrin
If you haven't put in mesh yet and trying to burnish read tip I left on bb1949's thread. It might be a help. BigGrin
George
Building HMS SOTS
#300 Posted : 22 June 2014 09:03:11
BigGrin Very nice work on the launch GeorgeCool
This page was generated in 0.976 seconds.
