Tools Options
MattWeatherly
#1 Posted : 28 June 2014 01:07:36
Rank: Newbie
Hi,
I'm new to this style of modelling (I've previously only done airfix). I've picked the RB7 nitro model as a start but from issue one I'm having trouble. Where do you get tools? It says to use a size 4 Phillips head screwdriver, and size 3 in issue 2. Where do you get these? Every precision screwdriver set I look at only has sizes 00, 0, and 1.
Thanks
Aquanin
#2 Posted : 28 June 2014 02:50:20
I used size 0 for the entire front and rear wing. Worked just fine.
Warthog
#3 Posted : 28 June 2014 08:39:04
First of all welcome to MS Matt BigGrin
There are plenty of screwdriver sets available on eBay and also from Maplins. As Aquanin has mentioned that a size 0 will do fine. It might be that your getting the screw size confused with the Screwdriver size.
Spencer
MattWeatherly
#4 Posted : 29 June 2014 02:54:21
Rank: Newbie
Thanks guys.
I have two issues to build now, looking forward to it.
Already planning my next build!
This page was generated in 0.936 seconds.
