Joined: 28/06/2014 Posts: 2 Points: 6 Location: Newcastle-upon-Tyne
Hi,
I'm new to this style of modelling (I've previously only done airfix). I've picked the RB7 nitro model as a start but from issue one I'm having trouble. Where do you get tools? It says to use a size 4 Phillips head screwdriver, and size 3 in issue 2. Where do you get these? Every precision screwdriver set I look at only has sizes 00, 0, and 1.
Thanks
Joined: 16/06/2014 Posts: 65 Points: 188 Location: Austin, USA
I used size 0 for the entire front and rear wing. Worked just fine.
First of all welcome to MS Matt There are plenty of screwdriver sets available on eBay and also from Maplins. As Aquanin has mentioned that a size 0 will do fine. It might be that your getting the screw size confused with the Screwdriver size. Regards Spencer
Thanks guys.
I have two issues to build now, looking forward to it.
Already planning my next build!
