19 Pages «<23456>»
Gibbo's DelPrado Victory Build Options
Gibbo
#61 Posted : 01 July 2014 12:50:01
Martyn Ingram wrote:
BigGrin Looks like new Gibbo Bril work rgd Martyn
thank you Martyn
Jesus-Belzheim
#62 Posted : 01 July 2014 16:29:09
Your tiling looks great Gibbo ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
Gibbo
#63 Posted : 02 July 2014 01:20:02
Thank you very much Peter, it was worth the time putting into it, you're doing a lovely job on yours, is that the Victory tile pack you are using ?
Gibbo
#64 Posted : 03 July 2014 01:25:00
Over the last couple of days i have been working on the "VICTORY" decal at the stern of the ship, i started by printing the decal onto clear decal paper but when applied to the ship the black backround just hid it, then i tried printing it with a black backround and it still did the same thing (picture 2), so i painted a panel on the stern with two coats of white acrylic (picture 3), then stuck the decal onto that (picture 4), when everything was dry i painted around the decal with black (picture 5).
Gibbo attached the following image(s):
oldstampman
#65 Posted : 03 July 2014 04:00:49
Hi Gibbo:
You victory is looking great especially the copper tape. I haven't gotten that far yet but I will be covering mine with copper also. Where did you get the copper tape?
Best regards.
Keith
Gibbo
#66 Posted : 03 July 2014 10:49:40
oldstampman wrote:
Hi Gibbo:
Best regards.
Keith
Hi Keith
thank you for your comments, very much appreciated, here is the link to the ebay store that i used, they sell the copper tape in different widths, my DelPrado Victory is 1:100 scale, i dont know if the copper tape i used is to scale for that model, i believe the DeAgostini model is 1:84 scale, so if you want it to scale then it might be worth asking one of the guys on here how wide the tiles are in the Victory Tile pack, i look forward to seeing it.
Cheers
Paul
www.ebay.co.uk/usr/rythe...k?_trksid=p2047675.l2559
Have a look at peter's tiling on his Victory, i think he used the tile pack, he should be able to help you with the tile size
http://forum.model-space...sts&t=4197&p=10
#67 Posted : 03 July 2014 23:11:57
Hi Gibbo!
Well done on the nameplate! I had similar problems with the yellow, inkjet yellow ink on its own isn't bright enough (or opaque enough) to cover a dark background, the printers rely on a white paper base to allow it to 'shine' through.
I think I forgot to mention that I used the white background decal paper in the end! Blushing
The black ink for the background behind the letters blended in perfectly with the Admiralty black once both had had a clear matt varnish over the top!Cool
Well done again!
PS In 1:100 scale the copper plates would be 4mm deep so our tape is only about a mm or so oversized, not worth slicing it down anyway!Crying (actual size is 4ft long by 1'2" wide)
#68 Posted : 03 July 2014 23:33:39
She is really starting to look the part Gibbo,great work so far ThumpUp
Gibbo
#69 Posted : 03 July 2014 23:46:21
Plymouth57 wrote:
Hi Gibbo!
Well done again!
Thanks Robin i'm really chuffed with it, still got to varnish it yet to seal it in.
Gibbo
#70 Posted : 03 July 2014 23:49:39
thanks Davetwin i'm really enjoying adding and enhancing what i now know was not a great model to begin with.
#71 Posted : 06 July 2014 09:42:11
Looking good Gibbo, very nice work on the nameplate...Cool Cool
Gibbo
#72 Posted : 06 July 2014 23:39:52
This weekend i decided to re-do the grating on the lower deck, i had already done some of the grating on the upper deck during the week
Gibbo
#73 Posted : 06 July 2014 23:46:53
Marked & cut out the sections ready to take the new 1.2mm grating from Cornwall Model Boats, taking a saw & drill to already laid decks is a scary thing, measure ten times - cut once.
#74 Posted : 06 July 2014 23:53:25
Now that I do like Gibbo, beautiful work on those gratings... Cutting holes in a previously completed piece is always scary and your advice of measuring 10 times and cutting once is so very valuable to all newcomers....Drool Drool .. Keep up the great work, will be following....
Gibbo
#75 Posted : 06 July 2014 23:56:01
I built the grating first and then built the frames around them, i found it a lot easier to stick the frames onto paper first, i marked two lines at 90 degrees to make sure they are square and when dry cut them out,and finally the new frames ready to go on.
Hatches 5.JPG (262kb) downloaded 40 time(s).
Gibbo
#76 Posted : 07 July 2014 00:02:46
Thanks very much Alan, your comments are always much appreciatedBigGrin
#77 Posted : 07 July 2014 00:40:57
Gibbo
#78 Posted : 07 July 2014 00:54:23
stevie_o wrote:
Nice work Gibbo, looking goodBigGrin
thanks Steve, those gratings are fiddly little beggarsCursing
Gibbo
#79 Posted : 07 July 2014 18:19:35
Gratings and hatches complete, waiting for ladders to arrive, next up the Rudder.
sparks
#80 Posted : 07 July 2014 19:04:24
Blimey Gibbo, that brings back some frightening memories Blink
Glad to see you are going for the improvements on your Victory, the gratings look great, be aware though that there are a couple of divisions in the forecastle gratings.
Well done again, nice to see another Del Prado in the mix.
Guest (31)
19 Pages «<23456>»
This page was generated in 0.337 seconds.
