Hi Steve, Like the look of the 4mm planking and the Danish sets it of a treat. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Lovely work there Stevie, decking looks fab..... Regards Alan
Nearly completed the 3rd pack now, just some trim around the poop deck edge and the deck cutout and Im done for this month The deck is done with the "weather it"" solution but this time a much weaker mix, i used a ratio of 1 part of the solution to 7 parts water as I wanted it not as dark as the Victory deck. This was followed by a Danish oil and alcohol mix. Another thing to note is that I have blacked out the 2 poop deck hatches as I didnt plank below them, I was getting low on my Tanganyka strips so just to be sure I saved as much as could. I think the black card will look fine once the hatches are on. Cheers Steve stevie_o attached the following image(s):
I used a Danish Oil and alcohol mix as well, the Danish Oil went on the boat............... Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
 Hi Steve Nice colour on the planks, will update mine over the w/e as I can carry on with her now Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Super deck colour Stevie, coming along really nicely.... Regards Alan
Steve Really like the finish on your decking. Looks like your going to have an excelllant model at the end of this build - very well done. Tony Happy Modelling
Thanks for the comments I have now completed the 3rd pack (stages 11-15) This only involved fitting the walnut trim around the cockpit and poop deck edges. I have just received stages 16-20 but these are the start of the x-section build, this build is unlike the Victory in that the x-section is combined throughout the build and not tagged onto the end. More soon, Steve stevie_o attached the following image(s):
 Nice progress Steve, the hard wood horns on the stern deck are sanded flush with the deck sides. Otherwise the cannon port strips will not fit. regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Andy, not faired the frames yet, wonder why the instructions make a point of saying to have a 2mm overhang? Nevermind Thanks for looking in Steve
 Yes i thought the same i think its so there is plenty of meat to sand back to the correct angle Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Steve, Nice work on the deck's good thinking about the type of wood. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
The decks are looking great  Great work
Really coming along beautifully Stevie....
Managed to catch up with my parts now, just fitted all the gunport cutout / templates. Should be making some more progress with this now along with the Victory hopefully as I currently have no plastic kits on the go I havent fitted any of the dummy gun supports as these were just squares of wood glued to the back of the cutouts, I plan to have the gunport lids closed on this one anyway as I'm not sure how the dummy cannon will look as there is no depth to the ports. More soon hopefully Steve stevie_o attached the following image(s):
Steve Really like the look of this one. Did not realise it had pre-cut gun ports which I think look really good and ensure a good result. Look forward to seeing more of your handiwork on his one. Happy modelling Tony Happy Modelling
Thanks Tony, Yes, the gunport strips are just a template for the spacing, there are 2 layers of planking to go on top yet and these are obviously cut to fit around the ports. Still saved a bit of work on the marking out etc Steve
 Hi Steve Some nice progress there, I have not received any of the dummy cannons as yet but i think they will be simular to the Victory ones Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Stevie, coming along very nicely indeed.....  You bring up a really good point that I hadn't really thought of relating to the dummy gun supports and their lack of depth... Think now you mention it the lack of depth would really look quite false on the finished build so the idea of closed gun ports would be preferable..... Am thinking more along the lines of removing the gun supports altogether and fitting full gun carriages, that would also get rid of the depth problem......  . Look forward to seeing more of your build.... Regards Alan
Thanks Andy, I reckon the dummy guns will come very late on in the build as per the Victory Alan, I'm just guessing about the final look of the gunports but on the Victory there is actual depth, about a 2cm recess where the dummy supports are set back so looks ok. Anyway, the decision is made now and I think will look fine with the lids closed, the top deck will be open as these are all full rigged guns. Cheers Steve
Guest (20)
