Suspension Lubrication Options
AndreZS1AZ
#1 Posted : 17 July 2014 15:26:32
I want to use PTFE (dry Teflon spray) on the suspension parts for lubrication. Will this affect the plastic parts? It should be inert but you never know.
It's not the fall that kills you, it's the sudden stop
Building: Bismark, 2.5m wingspan glider
#2 Posted : 17 July 2014 15:34:34
Unfortunately we cannot side with anything outside of what is provided.
AndreZS1AZ
#3 Posted : 19 July 2014 23:06:53
Ok Mr T, I see where you are coming from. We have the same policy in the motor trade. If you use something that is not policy, it will be upon your own head. Looking at the official build, I do not see mention of lubrication on the knuckles/ball joints, so I will use the Teflon spray to ease the friction slightly. I will take the punch if it does not workCrying
This page was generated in 0.207 seconds.
