32 Pages «<678910>»
tf64 Spitfire Build Options
#141 Posted : 28 June 2014 15:04:52
Hi,
UPDATE PACK 11.
Issue 40-43
Stage 40.
Contains:
Plastic Hinges.
1 Rudder section.
2 Wooden Strips.
Stage 41.
Contains:
Cockpit Floor.
1 Wooden Strip.
1 Diecast Part.
3 Brass Strips.
Stage 42.
Contains:
Seat Fret.
Diecast Headrest.
1 Wooden Strip.
Stage 43.
Contains:
Cockpit Sides.
Brass Wire.
Diecast Leavers.
Also include in Pack 11.
Lighting Set.
Not to sure how it all assembles but picture below.
I will be assembling shortly so pictures will follow.
Trev.
DJS
#142 Posted : 28 June 2014 16:29:34
Hi Trev,
I just thought I would add a post to say how much I am enjoying following and digesting your build diary. First class workmanship and excellent presentation and I await your posts with the same eagerness as Mr T's official build diary.
Keep it up and thank you for taking the time and effort to keep things up to date.
Dave
#143 Posted : 28 June 2014 19:06:08
Hello Dave,
Thank you for looking a my post, and especially your comments in your last post, today I have built the cockpit seat all went together well just a bit of adjustment but I thought I would like to see what it looked like and to dry fit to the fuselage (still waiting for it to dry ) that's as far that I have got so far, I will post soon.
Trev.
#144 Posted : 28 June 2014 19:12:45
BigGrin Nicely done TrevCool
#145 Posted : 02 July 2014 08:34:13
Hi Andy,
Thanks for your comments, back on the Vic now.
Trev.
#146 Posted : 11 July 2014 22:55:42
Great work there Trev, looking forward to your posts on pack 11.... Keep em coming.....Cool Cool
#147 Posted : 14 July 2014 23:00:34
HI Alan,
Just spotted your post,thanks for looking.
All the best
Trev.
#148 Posted : 14 July 2014 23:36:03
Hi Trev,
Just been having a read through your log. Some really fine looking work on show, will look forward to following your build.
#149 Posted : 15 July 2014 08:52:16
Hi Dave,
Thanks for your last post, well not much has been done on the Spitfire at the moment but I have lot's of bit's to build in at a later date so I will be posting as soon as I have completed the next stage.
Trev.
#150 Posted : 19 July 2014 23:53:26
Hi,
UPDATE.
Pack 11 Contains the Spitfire seat now I'm not to sure about the size of the seat regarding the back rest it look's a tad short but I may be incorrect, so I decided to fit it and see what it looks like when I receive the floor I can try it to the build. I found it very interesting to put together the only problem was I had a small gap were the base of the seat fits to the side which I had to fill, at present I have stopped at the primer stage but will investigate more, also I am not to happy with the seat straps I think I can improve I have a few ideas.
More to follow.
Trev.
#151 Posted : 20 July 2014 00:16:38
Lovely work again Trev, think you have done a great job on what looked like badly fitting parts.... looking forward to seeing your progress...
#152 Posted : 20 July 2014 09:03:05
BigGrin Nice work TrevCool
#153 Posted : 20 July 2014 10:23:12
Hi Trev, BigGrin
Nice work as always.Cool
I think the seat back looks short, because, the seat should be recessed to accommodate the pilots parachute.
Hope you don`t mind but I`ve attached a couple of pics taken at Duxford, when two guys from the "Flying Legends" gave me behind the scenes access to get some close-up shots.
Keep up the good work
#154 Posted : 20 July 2014 16:44:26
Alan,
Well I was not to pleased with the way the seat went together, all though
it did turn out sort of ok! I think I will rebuild from scratch and see what happens and how it looks.
All the best
Trev.
#155 Posted : 20 July 2014 16:47:59
Hi Andy,
Thanks for looking in, look forward to viewing your triny build.
Trev.
Warthog
#156 Posted : 20 July 2014 16:50:12
Doing a great job Trev Cool looking good
Spencer
#157 Posted : 20 July 2014 17:00:40
Derek,
Thanks for looking and for your help with the photo's, I will be re-building the seat I need to check out the CD first as I'm not to sure of the total height of the seat back or where the floor will be fitted, looking at your pictures (thank you) it has given me something to go by and think about, I will post as soon as I have something to show.
Best
Trev.
#158 Posted : 20 July 2014 17:32:17
BigGrin Lovely work m8 a bril fix on the seat ThumpUp Rgd Martyn
#159 Posted : 20 July 2014 17:36:31
tf64 wrote:
Derek,
Best
Trev.
Hi Trev,BigGrin
Glad to have been of some assistance.
When you work out some figures for appropriate sizes, give me a buzz.
I`ve made a quick scratch build in balsa and would like to compare the stats to see if we are on the same hymn sheet, so to speak.
This was about an hours work. (Including sizing)
#160 Posted : 23 July 2014 08:49:51
Hi Spencer,
Sorry I missed your post (157)thank you for looking and your interests.
Trev.
32 Pages «<678910>»
