 Rank: Pro Groups: Registered
Joined: 31/12/2011 Posts: 123 Points: 369 Location: Graz, Austria
Hi, shipmates! Only one gun still missing in the cutaway!   Finally a thin woodstrip on top to protect the frame parts   After adjusting the colors of frames and planks, this is the result     Greetings from Austria, Bernd
very nicely done bernd. great display. k. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Hi Bernd, That is really brill,  . I like the addition of the rib sections in the cutaway, a nice twist, much better than a large hole in the hull. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 01/04/2013 Posts: 342 Points: 1,029 Location: Essex
Absolutely brilliant Regards Alan England expects that every man will do his duty.
Fantastic work Bernd, really enhances the old girl...  .. Very well done.... Regards Alan
Joined: 12/04/2012 Posts: 29 Points: 87 Location: Melbourne, Australia
Fantastic Work Bernd Perksy
Beautiful and stunning job there Bernd. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Just shows what can be done great job “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
Stunning,the cut away done the way you have done it sets the whole thing off beautifully. Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
 Very nicely done Bernd Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
That cutaway looks absolutely fabulous Bernd  Truely wonderful work,especially given the lack of access and having to work inside out. Kind Regards Nigel
Very nice way to finish her off Bernd, looks stunning.... Regards Alan
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
It looks fantastic Bernd
Hi bernd. Fantastic job on your cuttaway. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Absolutely stunning finish, Bern. Those sailors certainly look like they've been in the wars.
Joined: 16/06/2013 Posts: 284 Points: 859 Location: Cape Town, South Africa
I became emotional watching your sailors at work. Your work visualise the strain these men had to deal with. I like the soot stains on their bodies. It gives a new dimension to the illustration of cannoniers at work. "Rather try and fail than had failed to try".Sovereign of the Seas Model Space forum: Marcel's build
Joined: 23/03/2010 Posts: 202 Points: 528 Location: Bedfordshire
Hi Bernd Absolutely Stunning Build You have been an inspiration and your pictures are so clear
This is my first ever large wooden build and i have just got to the sails i was planning on furling the sails but someone on the forum said they would look out of scale, would you happen to know the dimensions for the sails if i was to shorten them ?? any help would be gratefully received Thanks again Allan
Joined: 18/11/2012 Posts: 19 Points: 57 Location: Sutton, Ont., Canada
Hi Bernd
I have followed your build for almost two years now, you gave did a fantastic job and for this you should move to the Admirals Table. I have used a lot of your ideas in whole and in part over the past couple of years , well almost.
I am contacting you today on the 15 Eye Bolts around the Mizzen Mast, Do you have any information at all as to what all of these Eye Bolts are used for, I am at a loss as I can not find any rime or reason for all of these, mu kit calls for 15, the real ship has 6, could you help me out in this matter.
Once again you have did an excellent job on your build of the HMS Victory, you have created a beauty, well done. Enjoy.
Regards Lawrence
Thank you, Lawrence! No, I have no ideas what all these eye bolts are used for. In my case, 7 of those around the Mizzen mast remained unused. Best regards, Bernd
Joined: 17/02/2014 Posts: 124 Points: 376 Location: Wales, UK
Wow, what a beautiful build, wonderful work
Guest (11)
