3 Pages <123
part 19 "simulated decking" Options
willie
#41 Posted : 12 August 2010 18:36:25
Boaz wrote:
Refering to the cannons. Two questions.
Do you think we will be getting the 3 different sizes of the 12 pounder (short, medium & long)which are on the upper & weather decks?
How difficult would it be to re hash the build to be able to fit full cannons rather than the dummies?
Bob
i have the mantua victory it hase dummy connons apart for the ones you can see on the thired deck and the ones on topdeck if you look through the gun ports on the thired deck you can not see the hole cannon just the barrel of the complete ones there no much room between the barrel and the gun port
Boaz
#42 Posted : 13 August 2010 02:11:02
Thanks for that mike & willie.ThumpUp
Didn't realize how close the size difference was.
Think I'll leave it as is then.
Bob
DaveyB
#43 Posted : 13 August 2010 12:10:09
Rank: Newbie
Just another observation.
On page 12 of issue 19 there is the cutaway picture showing the cannons and crew....The detailed cannons appear to be a different size to those in the gunports next to them...So, either the dud cannons in the ports are too big, or the dorama cannons are too small for the deck level they are supposed to occupy.Confused
A solution to this would be to put the diorama parts on a top deck where you would get more visual benefit.
DaveyB.
3 Pages <123
