27 Pages «<1920212223>»
George1 Build Options
George1
#401 Posted : 27 July 2014 04:03:27
Whizgig wrote:
I know how you fell George I am 50 I have manic Bipolar Hsp and Sundowners syndrome ( like Dementia) I am like doing this for my sanity lol
Hi Whizgig. BigGrin
I have not been diagnosed with anything yet, but I just have a personal thought about keeping the mind active will help ward off some things like forgetfulness etc. That why I have a PS3 and play a lot of shooting type games as well as building this SOTS. I also wrote a number of books. Mainly "Shoot 'em genres". Not that it makes me any money as I'm only one of hundred's of thousands with ebooks/ibooks on the internet. BigGrin Laugh
I can do no more than wish you all the best mate for the future with your problems.
George
Building HMS SOTS
George1
#402 Posted : 27 July 2014 04:05:55
Pinks666 wrote:
hi,
this is great, I have just spent the last 15 mins pouring over the build posts, very much impressed.
I know what you mean about waiting for new issues, it seems to take an age for them to come, but I suppose that is part of the fun of building these.
I will be eagerly following this.
Marc
Hi Pink. BigGrin
Thanks for looking in and commenting. It's appreciated. Cool Cool
You're very welcome to look in anytime. Cool Cool
If I can ever be a help let me know. BigGrin
George
Building HMS SOTS
George1
#403 Posted : 27 July 2014 04:07:05
Ponty wrote:
your ship is looking very nice George!BigGrin
Hi Ponty. BigGrin
Thanks for looking in and your kind comments very much appreciated. Cool Cool
George
Building HMS SOTS
#404 Posted : 29 July 2014 00:11:40
Hi George, thought I would also post my reply to your question on your diary as I know you have a lot of followers from your neck of the woods and also just in case you do not visit my diary again soon and miss my response....
Hi Alan. BigGrin
Looking stunning as expected. Cool Cool
Hard to imagine a better build of SOTS. You really have excelled in the build. Cool Cool
While I'm on your thread can I indulge re a couple of queries?BigGrin
I notice your eyelets are black and as all this brass ware is only anodized metal and won't take a burnisher unless anodizing gone, is there a chemical that removes this anodizing rather than filing off as I've had to do re launch mesh. Would appreciate knowing as I really would like all brass ware that doesn't have to show as such to be black re the cannon fittings and all eyelets etc. I know ships those days had no brass ware or very little if they did as everything iron other than maybe bronze cannons and I'm not sure about those.Confused
The other query is regarding the stern. As planks have been laid I've left a rough overhang as I filled in. Can this overhang be taken off level with the stern line or does some overhang have to stay. I think I saw somewhere 2mm overhang but not sure. Thought I would do this while waiting on planks next issue if I know what has to be done.Confused
George
Thanks George, your kind comments are most welcome... Just home from work and read your post so thought I'd give a quick reply before getting down to some chores.. I tend to use two products available here, one is Krick and the other is blacken-it, both burnishing solutions and have found both to be equally as good. In order to get the best results I simply followed the thread posted by Magpie, the information he and others give here are well worth reading up on.. Here is the link to his thread....
http://forum.model-space...aspx?g=posts&t=5468
All the cannons provided are not brass but cast metal so painting is the answer here.. Instructions say to paint bronze but I went down the route of metal black...
Regarding the stern, the 2mm overhang on all the planks down both sides of the stern piece are needed so don't go cutting them flush with the stern. The 2mm overhang on both sides will create a slot down the length of the stern, into this slot you will fit the stern post to which the rudder will be attached.. By leaving the 2mm overhang you will end up with a much neater finish line up the entire length of the stern post.. The fitting of the stern post I covered from around page 68 of my diary....
Hope this all helps but if you need any more info then please get back to me...
George1
#405 Posted : 29 July 2014 03:23:36
Hi Alan. BigGrin
George
Hi Alan. BigGrin
Thanks so much for replying to my queries re your thread and here. It really is very decent of you to go to that much trouble and is very much appreciated.Cool Cool
I'm glad I asked about the stern planking as I know now just how important leaving that 2mm is for fitting of the stern post as you've described.Cool Cool
Will also eagerly look up that "Magpie" URL re burnishing. Thanks again it is appreciated greatly. Cool Cool
Will also look up your page 68 your diary. Thanks mate. BigGrin
George
PS. Hi Alan if you look in; The URL is only half alive and won't take me there re "Magpie".
Building HMS SOTS
#406 Posted : 29 July 2014 07:26:33
Hi George, try this to Magpie's thread...
George1
#407 Posted : 29 July 2014 09:51:21
Hi Alan.BigGrin
Checked out Magpie's URL. I have the blackener, but will need to purchase the Isopropyl Alcohol do do the job as described. Cool Cool
Will recheck once I have the gear to ensure I follow procedure. BigGrin
Thanks heaps for the URL it certainly gives me some hope now of blackening that anodized material. Cool Cool
Have already cut stern overhangs to 2 mm length straight in line with the stern. Looks much neater too now.BigGrin
George
Building HMS SOTS
#408 Posted : 29 July 2014 15:24:31
BigGrin Hi George
In the past i have used mostly the 'Krick' blackener which has worked very well most of the time but sometimes it wont quite go off so well and appears blotchy and not an overall even black colour.
As you probably already know from reading the instructions this is a chemical reaction type fluid and its the temperature that is most important to get the reaction to work.
So what i have learned to do if the reaction is blotchy or patchy is this, put your metal work and its container into a microwave cooker and heat at medium to high power for 1 minute then leave to await the reaction, just repeat until you get the desired effect/colour.
George1
#409 Posted : 30 July 2014 03:19:59
BigGrin Hi George
Hi Andy. BigGrin
Thanks for the above information on blackening. It is very much appreciated. Cool Cool
Anything that makes it easier than filing off anodizing to get the blackener to work is most welcome. Cool Cool
I will later put my results on this thread once I do the job. BigGrin
George
Building HMS SOTS
George1
#410 Posted : 01 August 2014 04:42:14
Issue 21 came on time.BigGrin
Have gone past current issue. BigGrin
Have now put 12 rows of planks bow to stern. (looks like 11 but pointed strake just on corner re a full plank to rear.) And 8 rows on hull bottom.BigGrin
Again ran out of planks to go further. Used all in issue. Bored
Pics below where I am to date. BigGrin
George
Building HMS SOTS
Whizgig
#411 Posted : 01 August 2014 05:06:25
you are doing well with the planking George
George1
#412 Posted : 01 August 2014 05:08:52
Hi Whizgig. BigGrin
Thanks, it's appreciated. Cool Cool
Getting there slowly. BigGrin
George
Building HMS SOTS
George1
#413 Posted : 01 August 2014 08:14:42
Hi Alan if you look in. BigGrin
Managed to purchase that Isopropyl Alcohol (.5 Ltr Squirt bottle) so will try to see if I'm successful blackening anodized pieces I have following instruction by "Magpie". BigGrin
Will put up pics if successful later. BigGrin
George
Building HMS SOTS
#414 Posted : 01 August 2014 08:39:19
BigGrin Lovely work on the planking George well done m8 ThumpUp Rgd Martyn
#415 Posted : 01 August 2014 09:27:57
George1
#416 Posted : 01 August 2014 09:33:23
Hi Martyn. BigGrin
Thanks for looking in and your kind comments. It is greatly appreciated.Cool Cool
Slowly getting there. BigGrin
George
Building HMS SOTS
George1
#417 Posted : 01 August 2014 09:35:24
stevie_o wrote:
That planking is really coming along nicely now George, Well doneBigGrin
Hi Steve. BigGrin
Thanks for the compliments. They are as always greatly appreciated. Cool Cool
I just wish there were more planks in the issues. BigGrin
George
Building HMS SOTS
#418 Posted : 01 August 2014 19:04:23
George
Hi George, I try to look in every day to yours and your fellow builders diaries from down under.. You've done a great job with the planking and the stern looks spot on.... Good luck with the blackening, its all about trial and error and I'm sure you will get there in the end... Look forward to your next post so until then, keep up the great work.... Cool Cool
John Passmore
#419 Posted : 02 August 2014 02:52:50
Publisher Medal: Featured Build of the MonthOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Hi George
Your planking is looking really good and way ahead of mine, which is good because I can pick your brain.BigGrin
I have 8 bottom planks in (4 each side) and having a bit of trouble keeping the plank stuck flat at the very end of the keel. I pin nail it and clamp it flat against the keel for at least 24 hours after gluing, but when I remove the clamp, the plank gradually lifts up one edge. I know it's caused by the 90deg twist in the plank, so did you have the same problem?Confused Confused
I've tried soaking and steam ironing the plank as well as cutting lots of grooves in it. Can you advise how you overcame this problem?
The keel planking on your model looks terrific...BigGrin BigGrin
JohnP
George1
#420 Posted : 02 August 2014 03:25:15
George
Hi Alan. BigGrin
Thanks for your kind words on my build. They are as always greatly appreciated and certainly gives me encouragement. Cool Cool
Now I have run out of planks again I will try to get into that burnishing now I have the ingredients. Will post some pics re results later. Mellow BigGrin
George
Building HMS SOTS
Guest (6)
This page was generated in 3.403 seconds.
