Joined: 16/06/2014 Posts: 65 Points: 188 Location: Austin, USA
I am assuming they will tell us how to adjust the steering servo once this thing is ready to drive, correct? Because as it is now it is not adjusted correctly. They tell you to screw in the ball end to the arm all the way. It seems all you have to do is unscrew the steering linkage until the servo saver is at 90 degrees but that is just a guess. Or sis I assemble something incorrectly? Thanks.
As with any RC setup, adjustments will have to be made. Throughout the series, there is information regarding suspension,servo, steering and throttle set ups. Regards Spencer
