ribs Options
colin
#1 Posted : 14 August 2010 23:23:50
Rank: Beginner Level 1
Hi,As we are now attaching bottom deck to ribs with tacks do we glue the ribs to the hull now or at a later stage or should i have already glued the ribs to the hull, Thanks,Colin.Confused
Zeptrader
#2 Posted : 14 August 2010 23:48:09
read this -
http://forum.model-space....aspx?g=posts&t=814
also the magazine tells you not to glue yet.
ajbird74
#3 Posted : 15 August 2010 11:16:53
Oh no!
Was just going to start gluing mine as I have now secured the first 4 decking pieces.
Should I
be waiting then as I was following the magazine instructions but do appreciate these can sometimes be out of step.
Hope you can advise.
Kind regards
AJB
Confused
Jack Sparrow
#4 Posted : 15 August 2010 11:45:20
ajbird74 wrote:
Oh no!
Should I
Kind regards
AJB
Confused
Once I had made sure everything was square and the 4 deck pieces were pinned, I turned the hull over, leaving the jig in place for the added weight to keep things square, then mixed up a 70/30 solution of PVA and brushed it in all the seams as per the magazine.BigGrin Cool Only thing was it needs longer then a day to dry properly........more like twoBigGrin Flapper BigGrin LOL .But once it was dry, the strenghth in the frame is suprising.Drool Also when i fitted the gundeck support beabs I used the solution again to fill the cuts whick allow the sopports to bend and also aroud the edge where the supports touch the deck. Its that strong now I reckon It could take a broadside from the real ship!!!!!LOL LOL Cool
Lonestar Spirit
#5 Posted : 15 August 2010 11:53:01
Jack Sparrow wrote:
ajbird74 wrote:
Oh no!
Should I
Kind regards
AJB
Confused
I agree, it is stronger now lol, but I dont think mine could take a beating off the wife, so I'm still treading carefully.
Besides, I though after the decks were in place we should glue the ribs with diluted PVA, or was I tripping on too much caffeine? lol
Ship Builds on the go
Jack Sparrow
#6 Posted : 15 August 2010 12:03:26
Lonestar Spirit wrote:
Jack Sparrow wrote:
ajbird74 wrote:
Oh no!
Should I
Kind regards
AJB
Confused
Thats exactly the way, PVA after pinning the deck!!BigGrin BigGrin
This page was generated in 0.166 seconds.
