21 Pages «<56789>»
John Passmore Options
John Passmore
#121 Posted : 13 August 2014 08:16:46
Publisher Medal: Featured Build of the MonthOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Hi John, looks to me like you are doing just fine. The small gaps on the bow can be filled in with wood filler when you come to the sanding stage, larger gaps can be filled with tapered planks... Remember also, everything will be covered up by the second layer so what you are trying to achieve with the first layer is a good smooth flow to the hull and a good grouding ready for the second layer... Link below is to the same area on my build and you will see your's is looking very similar so continue as you are.
http://forum.model-space...sts&t=5013&p=22
Keep following the build instructions and keep a close watch on Mr T's official diary especially from issued 22.
Will be watching to see how you get on....
Hi Alan
Thanks for the nice comments and confidence booster...I was just getting a bit worried about the look of things...and yes I'm following Mr T's official build with the utmost close scrutiny as well as the magazine...BigGrin BigGrin
Your advice is very sound of course and is appreciated...Cool
BigGrin
JohnP
John Passmore
#122 Posted : 13 August 2014 08:19:54
jonny7england wrote:
Looking really good John...Well done mate!! Wink ThumpUp
Hi Jonny
Thanks for looking in and the nice comment...BigGrin
JohnP
John Passmore
#123 Posted : 13 August 2014 08:43:16
George1 wrote:
Hi John. BigGrin
Looking good mate. Cool Cool
Yes you will find that there are a number of tapered planks from bow to stern re hull bottom. I checked Alan's and Tomicks builds counting off planks to see when and where to do. A couple do not go to the bow and finish around rib 5 and 7 to the stern which eventuates in more or less a straighter gap between hull planking and bow to stern planking which is then easier to fill in. BigGrin
As Alan says These planks are for cover and shape for 2nd lot of planking so as long as you're happy with the final finish a few pointed strakes won't matter. BigGrin
Does get a little tricky around stern re issues 23-25.I'm gonna' be following Alan and Tomick's build closely. Mellow BigGrin
Re your "Burnisher Query" my thread: You can get from bigger Gun Shops. My son got mine from the Midland Gun Shop, Great Eastern Highway. Don't know name of shop but easy to find in yellow pages under 'Guns or Firearms".BigGrin
George
G'day George - how'r yer goin'?
Thanks for looking in and responding.
Yes, Alan's put my mind at rest re the planks and I will also follow closely Mr T's official build diary...Cool
I wont get issue 21 till Thursday so I'm just about out of planks and now fiddling with the ships' boat.
There are no gunsmiths in Mandurah, the nearest apart from Perth, is Bunbury or Busselton. The 2 I spoke to were not sure what burnishing fluid was, mentioning 'blueing fluid' instead. Not being a chemist I don't have a clue. I'll check out that one you mentioned in Midland - thanks for the pointer mate.BigGrin BigGrin
JohnP
#124 Posted : 13 August 2014 10:57:36
John
Hope the building is going well.
While I cannot be sure if it would ship from the USA to Australia being a liquid the following may give you an idea of what this blackening agent actually is. There are other brands and it may be possible you have a stockist in Australia via one of your model shops - maybe one that specialises in model railways.
http://www.micromark.com...en-it-4-fl-oz,7267.html
The following link contains some useful info in using this and some of the other products in the range.
http://rrmodelcraftsman....aftsmantoolchest_02.php
Happy modelling
Tony
John Passmore
#125 Posted : 13 August 2014 14:16:36
birdaj2 wrote:
John
Happy modelling
Tony
G'day Tony
Many thanks for your useful input which in turn led me via www to possible Australian suppliers in Perth...BigGrin
I was in Swindon last year - got family in Wiltshire. Nice part of the world...BigGrin
JohnP
John Passmore
#126 Posted : 01 September 2014 08:41:41
Hi All
Progress for August 2014 - with some pictures;
* Repainted the ships boat, blackened mesh and fitted, assembled duck boards outside the boat, painted, then installed;
* Finished laying trial deck planking to middle deck, leaving plenty of space for dummy cannon supports. Will clear lacquer prior to fitting third deck;
* Continued hull planking up to issue 25. Got the plank ends up the stern post in a fairly straight line. Made a bit of a blue with the bow planking - the first 4 planks from the false keel are finished too long, taking up too much space towards the bows - consequently I ran out of room at the first bow former. I've compromised by ending bottom planks along the last upper hull plank...Cool Cool
Overall I'm happy with my planking, but any comments or advice will be appreciated...BigGrin BigGrin
JohnP
John Passmore attached the following image(s):
#127 Posted : 01 September 2014 22:28:40
Hi John, coming along very nicely and don't worry too much about running out of room at the bow for the planks, you're doing just fine.... remember, this layer is about getting a nice smooth shape to the hull, clean lines all ready for the final layer of planks which of course is the most important..... Cool Cool .. Deck planking looking great, very nice work there... Keep posting those pics.... Cool Cool
George1
#128 Posted : 02 September 2014 02:01:22
Hi John. BigGrin
Everything looking good mate. Cool Cool
Looks like you've got deck planking under control too. Cool Cool
Like Alan said you'll see where you need to put in pointed strakes to alleviate the curvature from bow to stern as that gap closes. BigGrin
The only assistance I can offer is watch when the gap closes at rib 26 or thereabouts to the stern to ensure planks close off that gap. I nearly made a mistake when following the narrowing of three planks at the stern as shown in Official Build as I had the start of the taper bow side of rib 26 and would have left a skinny gap at that point where I should have started the taper stern side of rib 26 and the three planks of full width would have closed it off perfectly. Better that you might have to narrow a plank there to fit than the planks not filling or you'll be having to have pointed strakes opposite one another. BigGrin
Of course as Alan says the most important thing is filling in with this first layer of planks.
George
Building HMS SOTS
John Passmore
#129 Posted : 14 November 2014 02:04:32
Hi Everyone - I'm baaa-aaack!
Sorry I've been AWOL for a while but my 14 year old wind-up lap top gave up the ghost a couple of months ago and I was loathe to go out and buy one of these new- fangled things with different op systems...Crying
Something about teaching old dogs new tricks...not possible in my case either...BigGrin BigGrin. Anyhow, the wife eventually went out and bought me a new one, so then I was FORCED to bite the bullet and learn my way around this new device. This has taken a bit more time, and then I had trouble with passwords in logging on to this forum...Mad Mad
Notwithstanding the foregoing trials and tribulations, I have been pottering along with my SotS build and have attached some pics of my progress to date.
BTW, issue 21 never showed up but I managed quite well without it materially speaking, and still have 3 unopened packs of bamboo on completion of hull plankingCool Cool
Kind regards to all
JohnP
#130 Posted : 14 November 2014 08:18:05
BigGrin Welcome back to the forum John . Lovely work on the planking m8 ThumpUp Rgd Martyn
John Passmore
#131 Posted : 14 November 2014 10:26:56
Thanks Martyn. 'Twas a bit of a frustrating period but gr8 to be back...BigGrin
Rgds JohnP
John Passmore
#132 Posted : 14 November 2014 10:51:26
Hi All
Below are some pics showing November Progress with completion of hull planking...Cool
The last picture shows detail of planks ending at the Starboard side gallery foundation plate. When I reached the top there was room only for one short 50mm piece whereas instruction says there should be two pieces. But if I put the second piece in, it would extend well beyond the top of the stern gallery...
There are 16 layers of planks from the bottom corner of the gallery to the top - the same as in the magazine and Mr T's official build diary, so I'm not sure how this situation occurred...Blushing
So can anyone advise if there would be a detrimental effect to the future build by omitting the second short piece - bearing in mind there would be only half the perpendicular elevation at the forward end of the short piece...Confused Confused
Rgds to All
JohnP
Whizgig
#133 Posted : 14 November 2014 11:50:44
She looks fantastic John, great work on the planking.ThumpUp ThumpUp ThumpUp
Eugene.
#134 Posted : 14 November 2014 14:58:38
hi john, very nice job there, keep up the good work.Cool BigGrin
#135 Posted : 14 November 2014 19:48:39
Hi John, lovely work and its great to see you back publishing your progress...Cool Cool .. Regarding your question, it really does not matter if the planks go above the stern gallery section as later in the build you will do some marking and some trimming back of the planks to give you the overall height... Variations in this part of the build is very common so just carry on as you are doing and add the extra plank....Cool Cool
Hope this helps however, any queries then let me know.
John Passmore
#136 Posted : 15 November 2014 15:04:15
Eugene.
Hi Eugene
Thanks for looking in and nice comments. Yeah, the planking was awkward to start with but once I got accustomed to it, it became easier and quite enjoyable.BigGrin
You will find it a lot easier with the balsa infills as well.Cool
Kind regards
JohnP
John Passmore
#137 Posted : 15 November 2014 15:08:16
Hi Karl
Thanks for looking in and the nice comment. Yep - I'm enjoying this little caper...BigGrin BigGrin
Kind regards
JohnP
John Passmore
#138 Posted : 15 November 2014 15:26:35
Hi Alan
Yes it's good to be back on board and thanks for the compliment.BigGrin
Thanks also for the - as always - sound advice re the second short plank and which has been followed today...It doesn't look too bad...Cool
You will note I have clear lacquered the middle deck planking in accordance with your earlier advice and it looks really good. A bit orangey in the photo but that is just the artificial light I have in here. The colour is actually very similar to the hull planking - which is how I wanted it...BigGrin Cool
Kind regards
JohnP
#139 Posted : 15 November 2014 23:23:50
Hi John, pleased the advice worked out for you.... Decking looks great, a job well done..... Cool Cool
John Passmore
#140 Posted : 27 November 2014 08:32:07
Hi Everyone
Collected issue 38 from the newsagent today - at last - a change of scenery!!!Laugh Laugh - but alas - I can't get to it yet as I still have the procedures of issues 35 and 36 to carry out...Blink
So not a lot of further progress for November, I was obliged to modify my build cradle as it was unstable whenever weight/pressure was applied to the bows or stern and tended to tip downwards...Crying Fixed that with two extension bars added...BigGrin
At the same time installed additional screws to allow for height leveling adjustment on all quarters, and extend width of cradle to accommodate thickness of second layer of planking and protective cushioning...Cool
I've sanded and filled one side of the hull and quite happy with the result - smooth as a baby's bum now...Laugh
Kind regards to All
JohnP
21 Pages «<56789>»
This page was generated in 0.317 seconds.
