BRASS BURNISHING Options
jethro
#1 Posted : 16 August 2014 16:42:26
BRASS BURNISHING FLUID?
DOES ANYONE KNOW ANYTHING ABOUT THIS STUFF
AS IVE NEVER USED IT BEFORE ,
THE ADDS MENTION SOMETHING CALLED PHOTOTECK
SO IS IT ASIDIC
EBAY WANT £14 FOR A 100ML BOTTLE SO HOW MUCH IS
NEEDED FOR MY BUILD
MY LOCAL MODEL SHOP DONT SUPPLY IT ANY MORE AND
COULDNT HELP .IS THERE A SUBSTITUTE?
JETHRO
#2 Posted : 16 August 2014 17:51:21
Jethro
Good day to you.
There are a number of manufacturers producing what I guess is a brass blackening agent I believe you are talking about.
I have tried a few but have found best results with one called "blacken it".
I purchased my bottle via a model shop on eBay.Its still listed against the following eBay item number
400740997999
However depending on how you are looking to finish your SofS build not really sure you would need this. Most of the castings are painted gold and the canons get painted as well.
Should you still be tempted then a bottle as above will last a long time as you use the product like a "sheep dip" (however do not use this on sheep LOL ). These are chemical solution so need to be handled and stored with care.
Hope this may be of interest.
Happy modelling
Tony
#3 Posted : 16 August 2014 18:00:36
Hi Jethro, in addition to the info Tony has provided you should find this link useful, it gives information on the blackening process..
http://forum.model-space...aspx?g=posts&t=5468
I use Krick blackening fluid and obtain mine from CMB, link also attached...
http://www.cornwallmodel...aldercraft_cannons.html
Hope this helps.
jethro
#4 Posted : 17 August 2014 09:31:50
Thanks guys for getting back to me so quickly
Ive taken it all on board and will check out your
links and go from there
Jethro
This page was generated in 0.622 seconds.
