 Hi Tony No problem at all hope i was of help and yes i agree about old eyes and there failings regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Love the update, such clean tidy work
Hi Andy. Looking superp. look forward to seeing more of your excellent build Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Hi Dave Thank you for your kind words Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Ian Thanks for looking in and your comments Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Cracking work Andy and your skill really shows with those bow posts.... if you have done them by eye only then it shows you have a keen eye for detail.....  .. One question, you say with the coats of Danish oil you have applied has left it looking a little too shiny for your liking and you intend to apply a matt varnish, just wonder why you wouldn't go with a satin varnish.... Satin is my preference simply because I love the finish it can give.....  .. Keep those pics coming.... Regards Alan
 Hi Alan Thanks for looking in and your comments, as for the matt varnish i was thinking along the lines of it toning down the deck with satin varnish being used on the inner balwarks and yes i do agree that Satin varnish gives a superb and subtle finish Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Some more progress on the hull but first I have taken some pic's showing how i carve out the pieces needed for the balwark cappings. I have now varnished the outside of the hull with firstly 4 coats of Shellac then 3 coats of satin varnish and then added the the top row of metal gun port's [ 2 short hopefully they will be supplied next month]. I wont be adding the lower ones yet as the doors are just asking to be broken off. Now all i have to do is finish varnishing the inner balwarks and add the capping's i have shown cut. More soon Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
What a beautiful looking finish Andy, all the coats of Shellac and Satin varnish has really brought out the best in the wood.... Simply fab work and thanks for sharing....  .. Great tip on how to do those capping too... Regards Alan
Andy You have a stunning finish on your model - very impressive indeed. Also have to take my hat off to you for your use on that razor blade to create the capping. That is some very skilful work to produce these all identical. Happy modelling Tony Happy Modelling
 Hi Alan Thanks for looking in and your comments , I must say the finish is even better in real life Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Tony Thanks for your comments always appreciated Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I have just had a look through this build and it is stunning!
 Hi All The final bits for this month are done although i will need to reseat a couple of the bow capping's as there not quite straight. The railings around the hatches have been fitted as has the railing around the central pin rails. Five pin rails have been made up and fitted around the mast's, that concludes this months issue, next month its back to the x-section. More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Nem Thanks for looking in and your kind words, very much appreciated Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good Andy, like the finish on the wood Steve
 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi Andy! A perfect work you made, very well done! Regards, Bernd
Although this doesnt quite have the bling factor of the SOS it really is a beautiful looking ship.
You are doing a great job with her
 Hi Steve Thanks for looking in and your comments Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi bernd Thanks for your comments and looking in Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (25)
