22 Pages 123>»
Hachette U Boat U-96 1:48 scale Options
daffy09
#1 Posted : 27 August 2014 19:36:36
Hi there fellow shipbuilders.
Saw this one advertised on TV today and wild horses couldn't keep me getting out to WHSmith to purchase this first issue. U boats have always had a strong fascination for me and my previous attempt at building one from card was doomed almost as soon as I started it.
So, this particular model is based on the U-96 which was a Type VII-C which was launched on August 1st 1940 and survived all its missions and was sunk at Wilhelmshaven in 1945 by US bombers after being decommissioned.
This submarine became the subject of the 1973 book 'Das Boot' which was made into a film of the same name and released in 1981.
The dimensions of the finished model will be 140cm in length and 13cm wide.
I shall be starting a build diary for this one, however, I intend to wait for a few weeks - or as long as I can before the temptation gets the better of me - before starting so as to get enough of the keel to get stuck into.
Happy building
David
daffy09 attached the following image(s):
#2 Posted : 27 August 2014 20:16:37
David
Certainly a full set of releases advertised last night from this one to a build your own Mallard loco to "nasty" creepy crawlies in resin.
Look forward to see how you get on with this one.
Happy modelling
Tony
#3 Posted : 27 August 2014 22:58:43
Hi David, looks like this could be an interesting kit to see come together... will be following your progress on this all the way.....Good luck with the build..... Cool Cool
#4 Posted : 28 August 2014 00:19:54
LOKI
#5 Posted : 28 August 2014 01:19:03
That's a healthy looking first issue!
I may have to wander down to my vendor and see what the first parts look like close up? I have seen elsewhere that a resin insert will be available for the torpedo room some-time soon?
Loki.
daffy09
#6 Posted : 28 August 2014 01:21:18
Thanks guys.
As I said, I won't be starting the build for a few weeks yet until I have enough parts to start getting my teeth into, so watch this space
Happy building
David
#7 Posted : 28 August 2014 09:57:40
Looking at some of the web sites it appears this model has already been running Germany for a few months now. From what I can see one of the main issues raised is the fact there are only 2 detailed compartments.
A look of talk of why the torpedo room was not opened as a detailed area.
In response to this the following company are offering a conversion set to allow the modeller to open and detail this section. All of the parts do add up to a fairly pricy conversion set in my humble view but guess it's down to the builder as to what they add.
Hope it is of interest.
http://shop.marinemodell...i597qaqmf6e0kvc5g98io7o
Happy modelling
Tony
daffy09
#8 Posted : 28 August 2014 13:03:34
Thanks Tony, that's really useful and something that I hadn't given any thought to. Yes, it would make a tremendous difference to the finished result to have a cutaway of the forward torpedo room. I've looked at the site and will do some hard thinking about whether or not go down that road. I think the extra expense would be worth it, but I have serious concerns about making such a 'mod' because I'm no expert at modelling and without any extra instructions about how to proceed with the conversion, I think I run the risk of compromising the finished build. Having said that though, the model is plank on frame, so if if I make a serious error, it's only a matter of re-planking the hull in that area and all would be rectified.
So thanks for the link Tony, I think I may have just talked myself into trying it.
Happy building
David
PS: Just to add to my comment about not being an expert at modelling and the need for instructions on how to build, as an example, I bought the gallery conversion for my DeAg HMS Victory and she's been sitting idle now (nearly a year) because I have no idea of how to go ahead with fitting it, and the build guide that was suggested for it hasn't been forthcoming.
#9 Posted : 28 August 2014 14:39:22
Post #135 and onwards of this link shows the fitting of the MWG gallery enhancement
http://forum.model-space...sts&t=2497&p=17
Get your self some MDF sealer such as Rustins quick dryng MDF clear sealer, as you'll likley be needing it.
Watching with interest Cool
daffy09
#10 Posted : 28 August 2014 15:12:34
Thanks for the link Tomick. I feel that I should make an apology here because I obviously didn't follow the guide through to the fitting - only got as far as the painting - sorry about that, part impatience and part forgetfulness, so will be able to move on with that one now.
And thanks for the 'heads up' on the MDF sealer, I'll have get myself some.
Happy building
David
#11 Posted : 28 August 2014 15:33:45
Was thinking you might have missed it.
Good luck with the U-boat build, a refreshing change of 'ship' product.
benny b
#12 Posted : 28 August 2014 19:29:14
hi got mine today just wondering where to put it at over 4 and a half foot long shes a big one I also picked up mallard as a top up the stash. benny b.
daffy09
#13 Posted : 28 August 2014 23:57:10
Nice one benny, did you see the post on here about the conversion kit for a cutaway of the torpedo room?
here's the link
it's a bit pricey but it may be worth it
Happy building
David
#14 Posted : 29 August 2014 11:07:26
The following site will show you the component breakdown for the first 30+ magazines.
http://www.u96-bauen.de/vorschau/
Happy modelling
Tony
daffy09
#15 Posted : 29 August 2014 11:57:25
Thanks for the link Tony, that was interesting. After seeing that I'm now tempted to make a start earlier than I expected too, but I still want to hold on until I make up my mind definitely on the forward torpedo room conversion. I think I'll buy the MDF parts for the conversion first, so they can be added into the build at the correct stage, then it won't hold me up on the rest of the build.
Happy building
David
KevinM
#16 Posted : 29 August 2014 17:25:53
Rank: Newbie
I too saw this ad on TV last night, and was tempted the second I saw it...
A quick question I have is, it looks like this is over 150 issues! Is it 1 per week? or 2 per month?
As it stands, even at weekly issues, that's 3 years to complete! Is that standard for these type of kits?
I'm still tempted, but the timescale is putting me off...
Cheers,
Kevin
#17 Posted : 29 August 2014 17:30:02
KevinM
#18 Posted : 29 August 2014 17:34:44
Rank: Newbie
Thanks for the info Steve,
Are Hachette known for keeping these kind of issues going right through to the final issue?
I am sure I have read about companies pulling the plug on this type of thing 2/3rds of the way through its life...That would be awful to spend 2 years building it, and then it getting pulled near the end!
It does look really nice though, but the 3 year build time, and the £895 price tag are currently dissuading me slightly :(
Kevin
#19 Posted : 29 August 2014 18:15:10
It's unlikely to be pulled, the cost is high as in all partworks but the payments are spread out for affordability, some people would prefer this to getting the complete kit in one go, even if there was one.
riff-raff
#20 Posted : 29 August 2014 18:54:16
OH NO!!!! Not MORE MDF !!!!Cursing Cursing
Built:
Guest (7)
22 Pages 123>»
This page was generated in 0.310 seconds.
