11 Pages <12345>»
Stevie's Santisima Trinidad Build Options
#41 Posted : 02 September 2014 18:52:12
At long last all the gunport template layers are in placeBigGrin
Before the bulwarks were installed I thought Id take Andy's advice and use planking on the inside, to make it a little easier though I wanted to get this done and painted first before it went near the deck.
I pinned the bulwarks in place and marked the decklines on both, then removed them to plank the exposed areas.
I have looked at dozens of paintings and drawings of this ship and even reports and diaries of the time of Trafalgar but there is no mention of a definitive colour for the red paint.
It's clearly not the same red ochre that is used on the inside of the Victory gunport lids as this is a very "Browny" red. The paintings seem to show a brighter red used and the reports speak of a "fiery red" so I had a mess around with some paints and tried to match them to the colour of the paintings etc.
The colour tester shows the 2 basic colours used and the final colour after mixing - the left colour is humbrol signal red, the center is Admiraly red ochre and the right is my final "Bright red Ochre" this was obtained by adding drops of red ochre to the signal red a couple at a time until I was happy - I now have the ratio noted for future useBigGrin I also gave the bulwarks a very light wash of Vallejo burnt umber.
I decided also to fit the step all along the bulwark, this appears in most of my paintings and drawings of the ship and is also included in the X-section build of this kit.I checked first that it wasnt included in later stages of this kit but no sign of it in the final pics either.
The step has appeared in various colours too, white, black, natural and red but I went for an ebony stain for mine. I will also probably have the capping rails in ebony but all other deck furniture and fittings are to be left walnut wherever possible.
OK, here are some pics so far
#42 Posted : 02 September 2014 19:10:45
Hi Steve, BigGrin BigGrin
That`s looking really good.
WTG Cool Cool Cool Cool Cool Cool
#43 Posted : 02 September 2014 19:55:56
Very nice Steve, I do like that Red with the black line underneath, it really makes it stand out
cruorangelussilicis
#44 Posted : 02 September 2014 20:17:54
Cracking build so far, I really like that red
#45 Posted : 02 September 2014 20:44:16
I had the same issues trying to find a suitable green for my adler loco build. Must have gone through 8 different greens before hitting one that looked ok to me.
That is some effort you have put in there and will give you an excellent model at the end.
Happy modelling
Tony
#46 Posted : 02 September 2014 21:02:43
Hi Steve,
Great work again, thank you for posting.
Trev.
#47 Posted : 02 September 2014 22:04:51
BigGrin Hi Steve
She certainly looks good with that red
#48 Posted : 02 September 2014 23:37:35
Looking fab Stevie, think this is going to turn out to be cracker......Drool Drool .. Nicely done....
#49 Posted : 03 September 2014 21:02:27
#50 Posted : 08 September 2014 18:51:23
OK, frames fared and planking has begunBigGrin
The instructions called for all the gratings and stairwell surrounds to be done before the first plank was fitted so I went along with this to get them out the way.
I then began planking up from the lower deck toward the bulwarks. After 9 rows on both sides were done the instructions then says to build and fit all the stairs and ladders.
Although I can see this is designed to break up the boredom of planking a bit I skipped this as I really want to get the planks up to the bulwarks asap, they are very vulnerable to breaking and the extra thickness of the planking will make them much stronger.
The planking on this kit is way easier than the Vic - there are no tight bends at all and I'm really enjoying it at the momentLaugh
#51 Posted : 08 September 2014 19:20:09
Looks like you got quite a bit of planking done Stevie and a great job you're doing too.... Very nicely done.....Cool Cool
#52 Posted : 08 September 2014 19:23:20
Very nice Steve, I like the comment about the lack of severe curves, means I am not dreading the planking stage as much as I was after reading other ship logs.
What glue are you using on the wood, in pictures 1 & 2 it looks yellow rather than a white PVA glue.
#53 Posted : 08 September 2014 20:04:00
Thanks for looking as always Alan, appreciate itBigGrin
@Dave thanks for looking in, the glue is Aliphatic wood glue from CMB, very fast grab and says "dries clear with a hint of yellow" Laugh more than a hint id say. I only use it for the frames and false keel and first layer of planks for its grab time and very good strength. I generally use thin CA for the veneer layer of planks where no strength is required.
About the plank curves, you dont plank the bow or stern transom area on this kit, they are added as blocks after the 1st plank layer is done and you then only plank these areas with the thin veneer planks. Whereas the VIc had some horrendous plank bending especially the near 90 degree ones at the transomCrying
#54 Posted : 08 September 2014 20:21:25
BigGrin Hi Steve
Nice start on the planking
#55 Posted : 08 September 2014 23:19:49
Looking great steve.Cool
J
Ponty
#56 Posted : 08 September 2014 23:57:19
looks like another fantastic buildBigGrin
#57 Posted : 10 September 2014 19:32:50
Thanks guysBigGrin
Just a single pic update, theres not going to be a lot to report whilst Im on the 1st layer of planking, I have managed to reach the bulwarks now and an much happier to have added the extra strength up there, bulwarks are now 4mm thick and very solid.
I think I will have a break from planking now and go back and finish all the ladders / steps that I have skipped.
#58 Posted : 10 September 2014 20:24:24
Lovely work as always Steve
I have mentally filed the planking the bulwarks for when I get started
#59 Posted : 11 September 2014 23:47:32
Very neat and tidy Stevie, looking great..... Cool Cool
captain bligh
#60 Posted : 24 September 2014 21:03:05
Hi Stevie....
I bought this one too... now it's a toss up between the ST and the SOTS..Decisions decisions...the difficulty is that one looks better than the other then back to the start again LOL happy modelling with the ST Stevie!
David.
Promise too much ...and many will be in search of you!
Guest (10)
11 Pages <12345>»
This page was generated in 0.289 seconds.
