It has been noted that the part numbering for each stage does not correspond to the pdf instructions which are downloaded each month. This is due to the inclusion of the X-Section build being incorporated within the main ship build. The problem occurs due to the fact that the X-Sections stages are not numbered on their packaging but are numbered throughout the pdf instructions, this in effect puts the packaged stage numbers out of sync to the pdf stage numbers by 5 stages, and this increases by 5 stages after each X-section pack is released. If you are building your model month by month as the packs arrive then you may not have even noticed this but if you are storing your parts each month for a future build then you may want to re-label your parts as they arrive with the corresponding pdf stage. It may also be an idea to store all the X-Section parts together after re-labelling themHere are the corrections in full - Updated Nov 29th 2015
Pack/PDF 01 - Stages 1-5 No changes needed Pack/PDF 02 - Stages 6-10 No changes needed Pack/PDF 03 - Stages 11-15 No changes needed Pack/PDF 04 - Stages 16-20 X-Section Pack 1 (1-5) Pack/PDF 05 - Stages 21-25 (Boxed parts wrongly labelled as 16-20) Pack/PDF 06 - Stages 26-30 (Boxed parts wrongly labelled as 21-25) Pack/PDF 07 - Stages 31-35 (Boxed parts wrongly labelled as 26-30) Pack/PDF 08 - Stages 36-40 (Boxed parts wrongly labelled as 31-35) Pack/PDF 09 - Stages 41-45 (Boxed parts wrongly labelled as 36-40) Pack/PDF 10 - Stages 46-50 (Boxed parts wrongly labelled as 41-45) Pack/PDF 11 - Stages 51-55 X-Section Pack 2 (6-10) Pack/PDF 12 - Stages 56-60 (Boxed parts wrongly labelled as 46-50) Pack/PDF 13 - Stages 61-65 (Boxed parts wrongly labelled as 51-55) Pack/PDF 14 - Stages 66-70 (Boxed parts wrongly labelled as 56-60) Pack/PDF 15 - Stages 71-75 (Boxed parts wrongly labelled as 61-65) Pack/PDF 16 - Stages 76-80 (Boxed parts wrongly labelled as 66-70) Pack/PDF 17 - Stages 81-85 (Boxed parts wrongly labelled as 71-75) Pack/PDF 18 - Stages 86-90 X-Section Pack 3 (11-15) Pack/PDF 19 - Stages 91-95 (Boxed parts wrongly labelled as 76-80) Pack/PDF 20 - Stages 96-100 (Boxed parts wrongly labelled as 81-85) Pack/PDF 21 - Stages 101-105 (Boxed parts wrongly labelled as 86-90) Pack/PDF 22 - Stages 106-110 (Boxed parts wrongly labelled as 91-95) Pack/PDF 23 - Stages 111-115 (Boxed parts wrongly labelled as 96-100) Pack/PDF 24 - Stages 116-120 (Boxed parts wrongly labelled as 101-105) Pack/PDF 25 - Stages 121-125 X-Section Pack 4 (16-20) Pack/PDF 26 - Stages 126-130 (Boxed parts wrongly labelled as 106-110) Pack/PDF 27 - Stages 131-135 (Boxed parts wrongly labelled as 111-115) Pack/PDF 28 - Stages 136-140 (Boxed parts wrongly labelled as 116-120) Pack/PDF 29 - Stages 141-145 (Boxed parts wrongly labelled as 121-125) Pack/PDF 30 - Stages 146-150 (Boxed parts wrongly labelled as 126-130) Pack/PDF 31 - Stages 151-155 (Boxed parts wrongly labelled as 131-135) Pack/PDF 32 - Stages 156-160 X-Section Pack 5 (21-25) Pack/PDF 33 - Stages 161-165 (Boxed parts wrongly labelled as 136-140)
The list will be updated each month as and when released up to pack 33.
Thanks for posting this Stevie, got all my parts numbered today and found it quite easy thanks to your post..... Thanks again
Joined: 15/09/2014 Posts: 60 Points: 156 Location: Prestwick
stevie_o wrote:It has been noted that the part numbering for each stage does not correspond to the pdf instructions which are downloaded each month. This is due to the inclusion of the X-Section build being incorporated within the main ship build. The problem occurs due to the fact that the X-Sections stages are not numbered on their packaging but are numbered throughout the pdf instructions, this in effect puts the packaged stage numbers out of sync to the pdf stage numbers by 5 stages, and this increases by 5 stages after each X-section pack is released. If you are building your model month by month as the packs arrive then you may not have even noticed this but if you are storing your parts each month for a future build then you may want to re-label your parts as they arrive with the corresponding pdf stage. It may also be an idea to store all the X-Section parts together after re-labelling them
Cheers Stevie.. will keep a note of this! Promise too much ...and many will be in search of you!
I decided to bring my plastic clip lock container containing all my parts inside out of the garage today as I didnt want to end up with warped parts.
Took the opportunity to sort through all the parts and put the correct numbers on, will update each pack now as it arrives
