Thought this may interest a few people here, for me it looks brilliant if you can pull it off. http://modelshipworld.co...php?t=12820&start=0
  and this from the day cabin...makes me think.  Check out the link at MSW.
 Rank: Vice-Master  Groups: Registered
Joined: 13/10/2011 Posts: 851 Points: 2,628 Location: Leeds, Yorkshire
Go for it Colin if you want. I think I will be satisfied with the best 'conventional' build I can manage.
I don't anticipate too many people ever wanting to peer into my model to that extent. If I can get a semi-museum quality job done then I will be looking for the next challenge.
Mike T
Joined: 20/03/2010 Posts: 498 Points: 1,522 Location: South Wales
Colin, are they photographic images pasted on to give depth etc, cos if so, that's a heck of an effect! Nice find mate. Ship Builds on the go
Yamato - DeAgostini Subscription - Highly Recommend This Model AKAGI - DeAgostini Subscription - Highly Recommend This Model RMS Titanic Lifeboat (Kind Gift from DeAgostini Crew)
It looks good but I wont be doing this, id rather make a quality model then start risking cutting the ship away just to see the cabin, as for the pictures and lights, as far as I can make out in his log he used images and printed out on the laser printer and folded and glued 'em, works quite well me thinks, the lights are good but way beyond me.
Joined: 03/08/2010 Posts: 39 Points: 117 Location: Grantham
Wow!! That's fantastic. I do like the idea of led lights in the gun cabins. May have to brush up on my GSCE electronics... lol.
Joined: 05/04/2010 Posts: 52 Points: 167 Location: Scotland
Colin once again you amaze me with your finds. LED isn't that difficult to do just expensive and you need to hide the wires coming out of the model to a power supply. For the very experienced you can even place them into the cannons to portray muzzle flashes. The link takes you to spaceship lighting but explains the basics hope it helps for those who are intersted in "lighting" their Victory. http://www.starshipmodeler.com/tech/mh_led.htm
leds are EXRETEMLY easy. you just need some wire, a few leds and a resistor and a battery.
anyway i wouldnt have used those leds, they look like 5mm ones and i would have used 3mm as they look way to big for the model.
i think as well as the images glue on he added a few extras like the rope looks real and so does 2 bits of the cannon. all round a very nice effect.
for those of you waitin until you have most of he issues you might want to consider this little aspect, how much room is around the cannon muzzle and the gun holes? for anyone else is it worth it to your pleasures?
i might consider this as electronics are my key thing lol
