7 Pages <12345>»
Whizgig's Artesania Latina 22516PD HMS Endeavour Bark 1768 Options
riff-raff
#41 Posted : 30 September 2014 16:27:19
Coming together nicely Laugh
Built:
Whizgig
#42 Posted : 30 September 2014 17:01:29
birdaj2 wrote:
Eugene
Well done your up and running.
Looking good so far.
Thanks Tony.BigGrin
Whizgig
#43 Posted : 30 September 2014 17:02:05
Thanks Rif-raff.BigGrin
Whizgig
#44 Posted : 01 October 2014 13:11:04
I have been busy today but managed to get some work done now onto the next step which is the mid ship cargo hold.
And the stern cargo hold.
I have finally finished fileing and sanding the false keel to get a nice flat even flooring for the decks and to level up some of the ribs as they were not squarely cut.
Shaped and fitted the plywood decks ready to be glued and nailed into place and then onto the next stage that is planking the steps and the decking.
This is an sample of the instructions and the illustrations that are provided with the kit and then you have a parts listing that you have to go through and gather and make the parts according to the description in the parts listing.
Now with the planking of the decks I was wondering if you could give me some tips on the best method of how to do this, I want to keep it as close to original so I have ordered the book Captain Cook's Endeavor (Anatomy of the Ship) Softcover but I can't get it until mid October.
I have done some research and found out that the plank size used was based on boards of 12 inches width by 25 feet long (actual), which at 1:60, equates to 5mm wide by 125mm long.
I was wondering what would be the best way of laying the planks and the best glue to use and how as I have not done this before I have looked at a few video's about it and of course they all do it differently.BigGrin
Eugene.
daffy09
#45 Posted : 01 October 2014 14:19:17
Good start there Whizgig, nice work.
Unfortunately I can't offer any help with deck planking advice, (I don't feel knowledgeable enough to give you my 2 cents worth)BigGrin but if you go to the forum jump at the bottom of the page, scroll down the list to 'MODEL MAKING KNOW HOW' then on page 2 you'll find a 'Deck planking tutorial' which hopefully should be of help to you. I'm sure lots of our friends on here will be able to offer advice as well.
Good luck and look forward to seeing more of your build progressing.
Happy building
David
Whizgig
#46 Posted : 01 October 2014 17:29:18
Happy building
David
I have searched the listing and can't find the one you are talking about.Blink Blink
Eugene.
daffy09
#47 Posted : 01 October 2014 18:29:41
Sorry if I've muddied the water Eugene.Blushing - it's definitely there, right down the bottom between the 'USA forum' and 'Sci-fi and space forum'
Happy building
David
#48 Posted : 01 October 2014 23:54:00
She's coming along nicely Eugene, keep up the good work.... As for deck planking, you could try using the search function at the top of the page, using key words you should find a wealth of information available on the forum through other build diaries...... Cool Cool
Whizgig
#49 Posted : 02 October 2014 06:27:23
Happy building
David
Thanks David I found it it was late at night when I was looking before so the old eyes were tiered.BigGrin BigGrin
Thanks Alan,BigGrin I didn't even think of that which is strange as I have made and ran many forums and ip boards etc. I must be just getting old.BigGrin BigGrin
Eugene.
Whizgig
#50 Posted : 02 October 2014 13:17:39
I have now done the fore and aft step veneers now to nail and glue down the plywood decks and get them ready for planking.BigGrin
The first of the three decks down.BigGrin
Eugene.
Whizgig
#51 Posted : 02 October 2014 15:03:17
The other 2 decks now in place.BigGrin
And yep it's an optical illusion as they are straight.BigGrin
Eugene.BigGrin
#52 Posted : 02 October 2014 16:27:59
BigGrin Stunning work there Eugene looking bril Cool Rgd Martyn
Whizgig
#53 Posted : 03 October 2014 09:26:50
Thanks Martyn,BigGrin BigGrin
Now for the hard work shaping the hull with the aid of a razor planer and the good old rasp file, I'll see you all in about a week.BigGrin BigGrin it will take that long go get rid of the amount of scrap that needs to be removed.Blink Blink LOL LOL
Eugene.
#54 Posted : 03 October 2014 10:32:51
Eugene
All coming along very nicely.
Hope your hull shaping goes well.
Whizgig
#55 Posted : 03 October 2014 12:48:33
birdaj2 wrote:
Eugene
Thanks BirdaBigGrin BigGrin
Well after about 3-4hours of laboring and covering myself and my wheelchair in shavings and sawdust BigGrin which brought back some good old memories from when I was a cabinetmaker and that wonderful smell of freshly cut wood.LOL sorry about that getting a bit carried away in the moment.LOL LOL
The hull shaping is done.BigGrin
The trusty tools of trade.BigGrin BigGrin
Eugene.
#56 Posted : 03 October 2014 22:48:21
She's looking good Eugene, well done on fairing the ribs.... didn't take as long as you thought, it is one of those jobs you're always happy to see finished.....Cool Cool .. You'll be planking very soon now....
#57 Posted : 03 October 2014 23:03:02
BigGrin Top job on the fairingCool
Whizgig
#58 Posted : 04 October 2014 09:33:31
Thanks Alan, yep once I got stuck into it it seamed to go very quickly the plainer did most of the work and being in the chair had some advantage as the legs are a good platform to work on and to hold the hull while filing and planing.BigGrin
I do have one problem though the fore and aft blocks for the hull are solid and hard and you can't push the pins into it and it is hard to hammer them in as well so I think I am going to have to drill into them and then CA glue the pins in place to hold the planking on, I have brought the planking clips that Karl suggested and uses and I have made the ones out of the clips as well so I should be fine in that regard.
Now I was thinking that I will do the planking in the traditional way without the infills as I have shaped the hull using one of the planks as a reference guide for shaping the ribs and I feel that it should be ok.BigGrin
Well the next step is to plank the decks and do the side rails then the planking of the hull is it best too:
1: Cut the planks to the correct length which is 125mm and then place them on the decking?
2: Glue the decking on then mark out the planks at the correct lengths with a pencil?
Eugene.
Whizgig
#59 Posted : 04 October 2014 09:34:02
Thanks MateBigGrin
#60 Posted : 04 October 2014 09:49:35
Great job so far Eugene, she is really starting to take shape Cool
7 Pages <12345>»
This page was generated in 0.200 seconds.
