7 Pages «<23456>»
Whizgig's Artesania Latina 22516PD HMS Endeavour Bark 1768 Options
#61 Posted : 04 October 2014 10:05:32
Eugene
Top job there on your hull fairing.
Especially impressed with your finish of those solid wood blocks on bow and stern because that is a difficult area to get correct.
Can see this turning into a brilliant model at the rate your going - very well done.
#62 Posted : 04 October 2014 10:58:43
Whizgig wrote:
She's looking good Eugene, well done on fairing the ribs.... didn't take as long as you thought, it is one of those jobs you're always happy to see finished.....Cool Cool .. You'll be planking very soon now....
Thanks Alan, yep once I got stuck into it it seamed to go very quickly the plainer did most of the work and being in the chair had some advantage as the legs are a good platform to work on and to hold the hull while filing and planing.BigGrin
I do have one problem though the fore and aft blocks for the hull are solid and hard and you can't push the pins into it and it is hard to hammer them in as well so I think I am going to have to drill into them and then CA glue the pins in place to hold the planking on, I have brought the planking clips that Karl suggested and uses and I have made the ones out of the clips as well so I should be fine in that regard.
Now I was thinking that I will do the planking in the traditional way without the infills as I have shaped the hull using one of the planks as a reference guide for shaping the ribs and I feel that it should be ok.BigGrin
Well the next step is to plank the decks and do the side rails then the planking of the hull is it best too:
1: Cut the planks to the correct length which is 125mm and then place them on the decking?
2: Glue the decking on then mark out the planks at the correct lengths with a pencil?
Eugene.
Hi Eugene, I find it always best to pre-drill the pin holes when planking, this way it helps to avoid bent pins but more importantly helps prevent splitting the planks and/or frames.... You don't have to use a drill bit, take a planking pin and cut the head off, insert that into your mini drill and you'll find it works just as well.
When planking the deck I would mark the deck ply with guide lines 125mm apart then cut the planks to suit. A little slower this way but you will end up with a better finish. Do a small practice piece using both the methods you outlined and see for yourself which method gives you the look you are after... Hope this helps...
Whizgig
#63 Posted : 04 October 2014 14:56:37
davetwin wrote:
Great job so far Eugene, she is really starting to take shape Cool
Thanks for your comments Dave.BigGrin
Whizgig
#64 Posted : 04 October 2014 15:02:47
Thanks for that Alan I will give the drill bit a try using a push pin with the head cut off.
Whizgig
#65 Posted : 06 October 2014 14:26:07
It was a bit strange to read in the instructions that it calls for doing all of the deck planking and to finish all of the decking and sides and then do the planking and the second finishing planking as well and then drill out the mast holes and the rudder holes after all this has been done??
So I decided to do it now before the deck and hull planking and putting on the side rails that could get damaged while I was drilling and filing.
I also beefed up the mast supports as by the time I set the drill down to the depth that they wanted them drilled too the drill hole went past the supports that they supplied.
This is the holes for the rudder.
And whoops!! I took out a bit to much when the file slipped and caught the edge of the plywood decking but all fixed.BigGrin
I filled in the rear sections as their isn't much holding the rear bit on and since I will have to nail in the planks and the rear section is so hard it might help to have some extra support.BigGrin
All of the hull preparations are now done and with a last going over and rechecking the ribs for beveling for the planking of the hull.BigGrin
Ok now to set out and mark up the deck planking I am thinking of cutting the planks to the standard of what they were back in the 17th century and doing some research I settled on 12" X 25' decking when scaled down to 1:60 = 5 X 125mm and using a 4 But system which is ( : - - - : ) please correct me if I am wrong Blink Blink
The first Row.
The Second Row.
The Last Row.
Eugene.
#66 Posted : 06 October 2014 23:29:10
Hi Eugene, you're certainly powering ahead with this build and she looks to be coming along very nicely..... Will be following.... Cool Cool
Whizgig
#67 Posted : 07 October 2014 05:38:57
Thanks Alan yes it is coming along quite smoothy and I find myself looking ahead at what needs to be done and evaluating the situations that are coming up with allot more incite than I did before so I must be learning something.Blink Blink LOL LOL
Eugene.
#68 Posted : 07 October 2014 09:43:35
BigGrin Lovely work m8 keep the pics coming ThumpUp Rgd Martyn
Whizgig
#69 Posted : 07 October 2014 12:28:54
birdaj2 wrote:
Eugene
A bit late on my reply mate sorry about that your post got lost in the rest of the posts, Thank you for your comments and yes they are a pain to do but the planer helped and did most of the work. It's a David brand here in Australia.
David Plane
Product Description
For flat, concave and convex planing, cutting and scraping into every corner. A strong and effective mini plane, its dimensions are 106mm x 54mm and features a durable aluminium body. This palm size plane is always sharp because it has a disposable replaceable blade. When dull on both edges of the double-edge blade, you simply throw it away and insert a new blade. The replacement double sided blades are available seperately in a pack of ten.
Supplied with 2 blades.
It is a four-way, three position mini combination plane with adjustable cutting depth:
Features:
smoothing plane with blade in mid position
corner plane with blade in front position
shaping plane with blade in rear position for convex planing
scraper blade with blade in front position
This plane is also very popular in the surfboard manufacturing industry. Model ship builders are also regular buyers of this wood working plane.
#70 Posted : 07 October 2014 12:38:27
Eugene
Your going really well with your build.
Interesting mention of the David's plane and it being popular with surf board builders.
I have one of these but have still to master it's use Confused you do have to keep that blade at the correct depth but even then I still struggle with it. Good to see it being used so well on your build.
#71 Posted : 07 October 2014 15:40:44
Whizgig
#72 Posted : 08 October 2014 13:25:53
stevie_o wrote:
Some nice progress there EugeneBigGrin
Thanks Steve.BigGrin
Eugene.
Whizgig
#73 Posted : 08 October 2014 13:27:51
birdaj2 wrote:
Eugene
Well I am used to hand planing so I guess that helps.BigGrin
Eugene.
Whizgig
#74 Posted : 08 October 2014 13:40:19
I have started in the planking of the decks and decided on a 3 but system as it was easier to mark out.BigGrin
Still a long way to go.BigGrin
Eugene.
daffy09
#75 Posted : 08 October 2014 14:41:39
Hi Eugene,
You're really getting stuck into this build now, lovely work. I like the detail that's going into the decking. Think you made a good choice on the method. Look forward to next update.
Happy building
David
Whizgig
#76 Posted : 08 October 2014 22:52:05
daffy09 wrote:
Hi Eugene,
Happy building
David
Thanks for your comments David very much appreciated.BigGrin
Eugene.
#77 Posted : 08 October 2014 23:19:47
Looking good Eugene, looking good....Cool Cool
Whizgig
#78 Posted : 09 October 2014 01:13:19
Ok 1st decking down 2 more to go.BigGrin
The good thing about taking the photo's is that it helps to see where you missed some nails as in pic no:3 this now has been rectified as I didn't notice them till I posted the pics.BigGrin
Eugene.
samson
#79 Posted : 09 October 2014 22:32:34
Hi Whizgig
spot on dekking job werry autentik Cool
will be following this build .
Cheers
Samson
Foz
#80 Posted : 10 October 2014 11:04:44
hi Whizgig
very nice work on the decking, keep up the great work and keep the pics coming.
Foz ThumpUp
7 Pages «<23456>»
This page was generated in 0.747 seconds.
