 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
At the bottom of the monocoque there seems to be what appears to be the lower wishbone pick up points inside it where the wishbones go into the chassis but there only seems to be them on the front 2 positions but only 1 of the rear ones have a pick up point hole, there doesn't seem to be one for the right hand side of the chassis.Is this correct? Just want to check before I attach too much to it.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Hi Steve All will be revealed in future issues so try not to look into what you may see as a problem that isn't actually there.. And to answer your question... It is correct. Spencer
Thanks Spencer. Just wanted to make sure it was ok. It just looked a bit odd that was all. At least I know the chassis is correct now Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
