Joined: 14/04/2010 Posts: 44 Points: 78 Location: cardiff
hms victory model Fairing the Hull can eany one give me a bit of help im not to sure wot to do thanks all
 Rank: Pro Groups: Registered
Joined: 30/03/2010 Posts: 126 Points: 335 Location: Bradford West Yorks
Hi Jony If you go into search and type in fairing the hull it will give you all the details and some superb diagrams on how to do it it is a bit daunting at first but take your time its a job you cannot rush and neither is it worth it as you could cock up all the planking also contact zeptrader ( colin) he is the expert hope this helps peter
Quote:also contact zeptrader ( colin) he is the expert Thanks Yorkieboy but I'm no expert, just like many here we have been there and learnt from experince, and sometimes its gone wrong, I dont want my model to go wrong as I'm sure all here feel the same, so any advice I can give is purley knowledge Ive picked up along the way.
