7 Pages «<34567>
Whizgig's Artesania Latina 22516PD HMS Endeavour Bark 1768 Options
Whizgig
#81 Posted : 10 October 2014 11:40:54
samson wrote:
Hi Whizgig
spot on dekking job werry autentik Cool
will be following this build .
Cheers
Samson
Thanks very much for you comments Samson much appreciated.BigGrin
But I have to note that I made some mistakes that I will have to rectify,Blushing
I put a line of nails by accident on pic 1 and 2 from the left row 8 at the center that should not be there and row 5 at the top from the left is crooked and the tenth board from the top after the cargo hold hole has been done as a 4 butt not a 3 butt and some of the short boards from the left have no nail holes the 1st 3rd & 5th boards from the bottom rear are missing nail holes and boards 1 & 3 at the rear top are also missing nail hols as well so if you are doing this take care and take photos and go over them with great care 2 or three times.BigGrin BigGrin
I will have to make some sawdust mix and fill in the holes to hide the marks and then redo them properly.
If anyone is interested I make it into a paste 1 part PVA wood glue to 1-2-3 parts sawdust of the same variety of wood I am using.
Now depending on how dry I need the mix or how thin a coat i need. The rule of thump is the deeper or wider the gap the thicker or drier the mix needs to be if that helps anyone who wants to make and use it, it has may uses and is a trick of the trade to us cabinetmakers.BigGrin
I used this mix in my SOTS build on the small Launch which is here.
Eugene.
Whizgig
#82 Posted : 10 October 2014 11:43:31
Foz wrote:
hi Whizgig
very nice work on the decking, keep up the great work and keep the pics coming.
Foz ThumpUp
Thanks Foz.BigGrin
riff-raff
#83 Posted : 12 October 2014 21:07:42
Well done mate - looks really nice !!!
Built:
cruorangelussilicis
#84 Posted : 12 October 2014 22:26:40
Great work so far, a lovely looking kit
Whizgig
#85 Posted : 14 October 2014 06:50:49
Thanks For the comments Mate much appreciated.
Whizgig
#86 Posted : 14 October 2014 06:51:18
Thanks Mate!
Whizgig
#87 Posted : 14 October 2014 11:18:49
Finally all of the decking is done.BigGrin
Eugene.
#88 Posted : 14 October 2014 11:47:14
Nicely done, looks really good LOL ThumpUp
#89 Posted : 14 October 2014 13:30:20
Thats a nice looking deck Cool
#90 Posted : 14 October 2014 23:30:01
Great work Eugene, deck looks fab....Cool Cool
George1
#91 Posted : 15 October 2014 02:52:00
Hi Eugene. BigGrin
Popped in to see what you're up to with this build. BigGrin
It's all looking very professional mate. Cool Cool
Regarding your sawdust and PVA fill. I used it myself early in the build when a clamp caused a depression. Good thing is once dry it sands down very smooth and better than filler in larger requirements. Cool Cool
Keep up the great work. Will look in again as you progress. BigGrin
George
Building HMS SOTS
Whizgig
#92 Posted : 15 October 2014 08:27:07
Thanks for your comments DaveBigGrin
Eugene
Whizgig
#93 Posted : 15 October 2014 08:27:35
Thanks JaseBigGrin
Whizgig
#94 Posted : 15 October 2014 08:28:07
Thanks AlanBigGrin
Whizgig
#95 Posted : 15 October 2014 08:29:14
George1 wrote:
Hi Eugene. BigGrin
George
Yep it works a treat George and thanks for the encouragement.BigGrin BigGrin
Whizgig
#96 Posted : 18 October 2014 12:05:07
I have started on the infills and opted for a easy layer on layer of 8x15mm lengths stacked up inside the cavities cut from 8x75x915 sheets of balsa wood.
I used my balsa stripper to cut the lengths at this rate it will take me about 2 lengths of the 8x75x915 sheets per side and at AUD$6.00 per sheet that is not bad AUD$24.00 for the whole ship to be done.
Eugene.
Whizgig
#97 Posted : 18 October 2014 14:53:15
I got sick of gluing and cutting so I decided to do some shaping instead just to break up the monotony.BigGrin BigGrin
As you can see from all of the shavings I did most of the work in about 1/2 hr with the razor plane it makes short of allot of work then I used a rasp file flat/round and then a fine file Flat/Round and then finished off with some sanding and will need a few little fills here and there but fine.BigGrin
Now to try and clean up the mess before the wife sees it.BigGrin BigGrin
Eugene.
#98 Posted : 18 October 2014 23:12:39
Coming along very nicely Eugene, great work on the infills....Cool Cool
daffy09
#99 Posted : 19 October 2014 01:42:18
Nice work there Eugene, should take a lot of hassle out of laying the planks.
Definitely worth the effort. Well done
Happy building
David
Whizgig
#100 Posted : 19 October 2014 06:56:43
Thanks Alan and David for your comments and encouragementBigGrin BigGrin
Eugene..
7 Pages «<34567>
This page was generated in 0.212 seconds.
