3 Pages <123>
Al's D51 build Options
#21 Posted : 11 October 2014 14:34:45
Thanks for the comments mr T, Tony and Steve they are most welcome.She will look good cleaned up and on her display base Cool
#22 Posted : 17 November 2014 01:04:04
Pack 19 has arrived BigGrin just a few pics of my progress.
The front of the tender detail.
Tender truck parts ready for the wheels next month.
#23 Posted : 17 November 2014 18:50:18
BigGrin nicely doneCool
#24 Posted : 17 November 2014 19:00:38
Thanks Andy BigGrin
#25 Posted : 17 December 2014 20:23:12
Next pack has arrived BigGrin
Bogies go together well and have some nice details.
Tender is getting quite heavy as well.
Will need a good clean up at the end of the build.
Not too much left to do now
#26 Posted : 17 December 2014 20:44:28
Nice to see meat being added to the bones, looks Cool
#27 Posted : 18 December 2014 07:45:23
Thanks Mr T.
#28 Posted : 18 December 2014 13:36:34
Looking Good. Wait till you see the base Drool Drool Drool
#29 Posted : 18 December 2014 16:29:14
Thanks Jase,can't wait to start building the base but shmbo may not be too happy when she sees the size of it LOL
Is there a going to be a cover for the base offered?
#30 Posted : 22 January 2015 20:57:28
Pack 21 parts.
Everything went together as per the instructions
The tender is almost complete.
Then the base ends assembled, its going to be a substantial weight once the base is completed.Flapper
Only 4 packs left but still lots to do.BigGrin
#31 Posted : 14 February 2015 13:20:07
Pack 22
Packs larger than normal and a lot to do.
A simple bolt together of the sides making sure the cut out is in the correct place.
A view of the base frame assembled.
The base top plates,i had a few marks on mine but these should be covered by future parts.
Parts fitted, its certainly a substantial display base.
The speaker unit parts.
The speaker parts fitted into the base.
Battery box and control panel switch assembly.
A closer look at the control panel, the switches work well.
A view from underneath showing the battery box and control panel, note the cutaway behind the battery box.
#32 Posted : 14 February 2015 15:59:36
Looking really nice Al. Your tender build looks very clean to me.
mark 2
#33 Posted : 14 February 2015 17:09:34
Hi AL BigGrin .
Your build looks fantastic and very clean.
Great job.
Best regards.
#34 Posted : 14 February 2015 17:37:28
Thanks Carl /Mark for the comments, this is my first brass build so has been a bit of a learning experience BigGrin
#35 Posted : 14 February 2015 19:17:31
BigGrin Nicely done AlCool
#36 Posted : 16 March 2015 17:46:50
Thanks Andy.
#37 Posted : 16 March 2015 18:08:47
Pack 23, not many left to go
The parts
The sound unit
A straightforward fit and connection.
The sleepers and ballast.
first i dry fitted everything
The rolling road parts.
The rails
All fitted and secured.
#38 Posted : 16 March 2015 18:49:07
BigGrin The base looks great with everything added and the case when it goes on sale will look the bizz on itCool
#39 Posted : 16 March 2015 20:42:47
Thanks Andy, definitely need the case to keep the dust off it BigGrin
#40 Posted : 17 April 2015 21:48:12
The penultimate pack.
The ash box fitted.
The motor parts.
The motor fitted and working BigGrin
The gearbox parts.
Gearbox fitted and tested.
Brake parts.
Brake parts fitted
Guest (11)
3 Pages <123>
This page was generated in 0.259 seconds.
